[ICEM] Set Vertex Location?
Old   April 24, 2013, 10:57
Default Set Vertex Location?
Javi
FJSJ is on a distinguished road
Hi guys,
I just want to know if itīs possible to give a explicit location to a vertex. I mean, select a vertex and give it x,y and z coordinates. Thanks!
FJSJ is offline   Reply With Quote
Old   April 24, 2013, 11:06
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
yes it is possible:
under blocking tab -> move vertices -> set location
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   April 24, 2013, 11:25
Javi
It was a lapse. I use this option everyday but usually itīs only to equalise location.
Thanks Diamondx!
Old   April 24, 2013, 11:33
Javi
I have another one. Look the picture. Iīve asked a similar question in other thread. Is not possible get the internal vertex location? When I click in green one, appears a big yellow point but, if this is an internal one... appear a small yellow point (I suppose that this measure itīs not the real of the vertex).
Old   April 24, 2013, 13:03
Far
Sijal
Originally Posted by diamondx View Post
yes it is possible:
It is the solution.
Here you have three options:
1. You are just talking about
2. Reference from "screen" Just create a point at required location and choose that point when you enable screen option
3. Don't choose any reference vertex or reference location. Just check X, y and z boxes and enter required location and apply.
Old   April 24, 2013, 13:19
Far
Sijal
You can right click on vertex (under blocking) in left panel and click on "show vertex info" and select the vertex who info is required.
Old   April 24, 2013, 13:21
Javi
Thanks Far. Iīve done this to set a location. But.. Do you know how to get the location of an internal vertex.
[blockMesh] Internal walls of zero thickness anger OpenFOAM Meshing & Mesh Conversion 23 February 6, 2020 18:25
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
how to move a set of vertex cthsieh Siemens 2 September 5, 2007 20:18
Determine the exact location of the vertex center? Anna Main CFD Forum 3 April 4, 2006 11:04
How to set transition location DAK565656 Siemens 3 September 6, 2005 05:44
