May 7, 2013, 17:00 |
uniform grid in Fluent
Stephan Langenberg
Rep Power: 14 |
In order to get an uniform grid in Fluent I tried the cut cell method in the assembly meshing layer. This leads to a nearly uniform cube grid.
There are two issues that I want to improve in my next working sessions. A) A "real" uniform grid exists out of one kind of cell with an equal size (for example only cubes). Is there a method in fluent or cfx to transform the geometry into a uniform grid without curves? B) If I use the cut cell method I'm limited too less thousands of elements. The mesher sends me the error "too much elemets for the assembly - method". Is there a easy way to fix this? |
Channel flow using InterFOAM | DanM | OpenFOAM Running, Solving & CFD | 49 | July 31, 2020 11:43 |
Problem in running ICEM grid in Openfoam | Tarak | OpenFOAM | 6 | September 9, 2011 17:51 |
rhoSimpleFoam | claco | OpenFOAM | 7 | April 20, 2010 04:32 |
buoyantSimpleRadiationFoam | msarkar | OpenFOAM | 0 | February 15, 2010 06:22 |
Grid for Fluent v.4 using Gambit? | Ray | Main CFD Forum | 3 | October 27, 1999 12:35 |
