[ICEM] Need help with volume meshing
Old   May 10, 2013, 20:36
Exclamation Need help with volume meshing
badboyz31 is on a distinguished road
Hi, I'm still a newbie to the ICEM and a new member to this forum and I have a problem with ICEM.
Currently, I'm trying to analyze a supersonic aircraft in cruise condition. Hence, I imported the model from STEP/IGES, enclosed it with a block-shape surface (as the farfield boundary), and meshes the surfaces (unstructured).
I also created a body called FLUID to determine the air in this system using 2-point centroid method (the material point is located outside of the aircraft).
Now, I want to know how do I volume mesh it with delaunay method ?
I mean the important settings since the "help topics" doesn't enlighten things enough for me.
If there's information which I haven't given, just ask for it.
Thanks in advance.
badboyz31 is offline   Reply With Quote
Old   May 11, 2013, 07:57
Stuart
ShowponyStuart is on a distinguished road
It will help people look at this is you can provide pictures and the mesh files. That way people can have a better idea of whats happening.
ShowponyStuart is offline   Reply With Quote
Old   May 11, 2013, 10:31
I've surface-meshed the entire surfaces, the only thing left is the volume meshing of FLUID part.
Old   May 11, 2013, 16:58
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
when you generate a volume mesh, you get to choose between octree and delaunay... it is up to you to choose there. Does it answer your question ?
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   May 11, 2013, 19:29
Well, I've seen both choices. However can anyone tell me the steps to volume mesh either with octree or delaunay ?
It seems that Delaunay has fewer options to choose from so I think I'll start with it.
Problem of simulating of small droplet with radius of 2mm liguifan OpenFOAM Running, Solving & CFD 5 June 3, 2014 02:53
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
'Tetrahedral meshing has failed for volume...' Murat FLUENT 5 February 19, 2011 04:22
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
volume meshing nikita FLUENT 1 July 3, 2003 01:25
