[ICEM] How to merge a surface to another in ICEM ? |
May 15, 2013, 07:21 |
I've just imported a model into ICEM CFD and it consisted of curves only. The model can be seen below.
So I can create surfaces from the body and its fins (2 large ones and 2 small ones). But I want to merge the surfaces of the fins to the body so I will be able to mesh it correctly. The fins were not attached to the body since there weren't any point in the model. What should I do to attach the fins to the body ? |
May 16, 2013, 03:06 |
Javi
Iīm not very sure if I understand your doubt. But... if you want to add the finīs surfaces to the body you can "right click" in bodyīs part, where you have the rest of your body, and then "add to part" -> "add to part by selection" and then Itīll open a pop-up and you can choose the entities you want. In your case, surfaces.
May 16, 2013, 06:54 |
#3 | |
[Commercial meshers] Merge Hexa ICEM | ignacio | OpenFOAM Meshing & Mesh Conversion | 1 | May 8, 2013 15:43 |
surface flow lines in ICEM postprocessing | Dimitri | CFX | 0 | July 18, 2007 11:30 |
ICEM Surface from points cloud ? | Guillaume | CFX | 1 | June 13, 2007 14:42 |
ICEM CFD surface mesh | Francesco | CFX | 1 | May 31, 2006 11:09 |
How can I define a intersection surface with ICEM? | BEN EZZEDDINE Anouar | CFX | 0 | November 15, 2005 06:05 |
