[ICEM] Why Prism Incomplete?
Old   May 24, 2013, 23:03
Default Why Prism Incomplete?
mohamed khedr emam
m5edr is on a distinguished road
Hi Experts
I built a simple prism around wind turbine blade (see picture 1) BUT the Prism is Incomplete along the blade (see picture 2) , for the prism parameters (see picture 3). Why?
Thanks in advance
m5edr is offline   Reply With Quote
Old   May 25, 2013, 03:32
siw
Stuart
siw will become famous soon enough
Just as a test - is the prism layer incomplete if you let ICEM float them when they are generated? To do this set zero values for the initial height and the total height. By doing this ICEM will nicely size the prisms so that the transition from the last prism to the first tetrahedral is smooth. After that you can split and re-distribute the prism to suit (to a certain extent). It may not give you the exact prism mesh you what but it may go some way to getting a complete prism mesh.
siw is offline   Reply With Quote
Old   May 25, 2013, 07:34
mohamed khedr emam
I did this step But the same error in prism also produced (see figure)
Old   May 25, 2013, 15:22
siw
Stuart
Are you generating the prisms into a volume full of tetrahedral elements or are you generating the prisms first and then filling the remainder of the volume with elements?
Whenever I make a hybrid mesh in ICEM I always follow these steps:
1) Use the Octree method to fill the volume. Delete the volume elements. Check and smooth the surface elements.
2) Use the Delaunay method (TGlib and Use AF = ON) to remake the volume elements. Check and smooth.
3) Generate the prism elements. Check and smooth.
Upload your files as it may be easier to get a fix.
Old   May 27, 2013, 05:40
AB
BrolY will become famous soon enough
prism angle = 180 might help.
otherwise, you can find a link to download Simon's tips and tricks for ICEM.
this document would help y ou.
BrolY is offline   Reply With Quote
Old   June 1, 2013, 04:19
mohamed khedr emam
I tried these steps BUT nothing new , the same results of incomplete prism
I attached my files (the prism setup is found there)
Old   June 1, 2013, 04:25
mohamed khedr emam
Otherwise, you can find a link to download Simon's tips and tricks for ICEM.
Yes I read this tips before But 180 prism angle where this angle prevent pyramids but also make worst prism quality.. However thanks for your recommendations
Old   June 3, 2013, 02:51
AB
You don't really mind about the prism quality; for example, CFD++ accepts prism with quality < 0.001 ... And prism are almost always bad quality ...So, the min angle would help to fill the prism around the blade, which looks like to be your main issue here !
Old   June 3, 2013, 10:47
mohamed khedr emam
I knew the prisms usually have low quality but Fluent not always comfortable with this low quality and always notify for this issue , and during my little expiercnce , Fluent may be not accept the mesh in some cases , Could you explain more about this?
O.K Thanks, but let me ensure that I'm understand right "The only solution to my case (not all cases) is kept my min. angle = 180"
Thanks in advance
Old   June 3, 2013, 10:51
AB
Not the only one ! But it might help.
Also, there are old thread about that issue ...
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
Problems building Paraview 3.12 on Gentoo Linux pajot OpenFOAM Installation 11 April 11, 2013 08:09
[swak4Foam] installing funkySetFields igo OpenFOAM Community Contributions 1 November 20, 2012 20:16
Getting prism to inflate into mixed tet-hex meshes Joe CFX 16 October 10, 2011 07:06
Icemcfd: Preventing prism inflation collisions? Joe CFX 1 July 31, 2007 09:13
