[DesignModeler] combine two parametric geometry |
May 1, 2012, 01:48 |
Houman Tamaddon
Rep Power: 14 |
Hi guys,
I have already buit 2 parametric geometry in seperated DesignModeller components in a workbench, I was wondering how can I combine (assemble) them and still keep them parametric? Last edited by Houman; May 2, 2012 at 01:49. |
June 12, 2013, 12:12 |
Zakaria
Did find a solution to your problem? I have the some one If yes, I'd be gratful if you can share it with me. Thank you |
June 12, 2013, 12:50 |
Ghazlani M. Ali
Rep Power: 29 |
design modeler does not support assembly... you can combine two geometries by loading one after another, but no parameters will be kept. i am 75% sure of what i just said...
June 13, 2013, 04:05 |
Zakaria
:-( Thanks Diamondx
assembling, design modeler, parametric geometry |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 19:42 |
[DesignModeler] Error while Loading a Geometry | JD944 | ANSYS Meshing & Geometry | 0 | October 25, 2011 14:51 |
[Gmsh] Problem meshing an imported geometry | Alicia | OpenFOAM Meshing & Mesh Conversion | 0 | March 30, 2010 04:53 |
Simulation of Flow through Complex 3D Geometry | EmersonKB | CFX | 5 | July 2, 2009 08:17 |
vitual _ real | deneb | FLUENT | 3 | January 22, 2007 04:31 |
