[ANSYS Meshing] Duplicate faces in Spaceclaim |
August 15, 2017, 18:22 |
Lisa
Rep Power: 9 |
Hi Guys, hope you are doing great.
I am modeling a helical pipe encased in a solid medium (backfill). The medium is surrounded by soil. The pipe has water inside. I created a hollow pipe and then imported it to Ansys (SpaceClaim). I then created a cylinder surrounding this pipe and used the merge command to get a cylindrical backfill around this pipe and water (body inside the helical pipe). The backfill is surrounded by cylindrical region of soil. When I take this model for meshing I run into problems with contact regions. I looked at my geometry again and when I use Repair>Fix>Duplicates, there are 11 duplicate faces. If use automatic repair, the backfill disappears. Is there any way to avoid these duplicate surfaces? |
August 16, 2017, 19:24 |
Rep Power: 14 |
don't create pipe separately, use a solid cylinder and use it as a pipe with fluid thru it and then create sand around it.
it will be really helpful if you can post some pics and explain further so I can suggest right solution |
August 17, 2017, 16:49 |
Lisa
Rep Power: 9 |
Hi Kapi,
Thank you for you reply. Here is the image of the geometry: I looked at through https://support.ansys.com and found that duplicate faces in Spaceclaim are fine if there are touching faces. The contact problem I was having during meshing was caused by the contact tolerances set too high. I think reducing this fixed the problem. Still keeping my fingers crossed though for the next steps. Let me know what you think. |
duplicate surfaces, geometry ansys, spaceclaim |
Decomposing meshes | Tobi | OpenFOAM Pre-Processing | 22 | February 24, 2023 09:23 |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 91 | December 21, 2022 04:50 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 10:58 |
