[ICEM] Exporting geometry as parasolid format
Old   June 26, 2013, 02:38
Post Exporting geometry as parasolid format
TA Ramanathan
taram is on a distinguished road
Hello all,
I am facing a problem regarding scaling up of geometry while exporting .tin into .x_t file. From ICEM CFD, I need to export the geometry as .tin into .x_t file in order to edit the same in UG 4.0. The existing geometry is in mm which is converted into Metre units (geometry getting scaled up) while exporting that as parasolid from ICEM. Please give your suggestion regarding this issue. Thank you.
taram is offline   Reply With Quote
exporting geometry
[ICEM] Best way to import geometry ICEM Cottbus ANSYS Meshing & Geometry 4 June 12, 2012 09:42
Exporting Structured format of CGNS shainath Main CFD Forum 0 February 7, 2012 23:06
[Netgen] Error message when exporting to OpenFOAM 1.5 + format almir OpenFOAM Meshing & Mesh Conversion 2 May 25, 2011 04:30
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 04:53
Problem importing GAMBIT mesh to Ansys geometry David G. CFX 0 June 19, 2005 06:01
