[Workbench] Which input file format can be used to import geometry |
July 31, 2013, 16:05 |
Chaithu
Rep Power: 12 |
Hi friends,
I am new to ansys workbench and have a problem to carry out my project. Please excuse me if the problem is silly. The problem is, I am given set of .geomTurbo files with specified geometry profile of rotor. The problem is we cannot use Numeca and my professor has asked me to use these files in other format and use Bladegen or Geometry Component systems in Ansys workbench. Since I am new, I do not know, to which format I shud change the given file. I am attatching a screen shot of the file. It will be very helpful if someone can help me out. Excuse me if the problem is very silly or easy. Thanks a lot. |
January 17, 2018, 21:12 |
Shihar
Rep Power: 8 |
Hi did u manage to build the impeller from the file in ANSYS , i have the cordinates of the radiver blade but was not able to create the full geometry of the impeller in ANSYS?
GPU Linear Solvers for OpenFOAM | gocarts | OpenFOAM Announcements from Other Sources | 37 | August 17, 2022 14:22 |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
[swak4Foam] problem on installing swak4Foam | navid2 | OpenFOAM Community Contributions | 2 | May 30, 2012 04:32 |
