[ICEM] Multiple Pipe in cylinder
Like Tree5Likes
Old   August 1, 2013, 08:47
Default Multiple Pipe in cylinder
Peyman
Peyman_m is on a distinguished road
hi every body,
anybody can help me to meshing this model?
thanks.
cfluid likes this.
Peyman_m is offline   Reply With Quote
Old   August 1, 2013, 13:33
Arrow Geometry
Jan
Jan Smedseng is on a distinguished road
Are the Files available?
You want to have a hexa blocking?
Regards,
Jan
Jan Smedseng is offline   Reply With Quote
Old   August 1, 2013, 14:42
Peyman
hi jan,
yeah of course, full hexa mesh
the model is here
http://upload.ugm.ac.id/278Part8.igs
thanks very much for your attention
Old   August 1, 2013, 15:03
Javi
FJSJ is on a distinguished road
I´m not very sure... but I think Diamondx did something similar with an injector. But only 1/4 of the cylinder.
FJSJ is offline   Reply With Quote
Old   August 1, 2013, 15:16
Peyman
the fluid is flow over the tubes in T junction
Old   August 1, 2013, 22:49
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
Observe this blocking , start with one o-grid, an do the necessary slipts where you see them, and finale you will take care of the big pig in the middle...
Good luck and get back to us if you could not succeed
PS: I love this bruce lee image, I laughed very hard when i first discoverd it. The purpose in posting it is not to say that i'm strong like him, it is just for fun, this is where i got it from:
http://iwastesomuchtime.com/on/?i=27507
i like to use since then
Far and FJSJ like this.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   August 2, 2013, 07:54
Peyman
thanks diamondx, ok, I will try,
Old   August 5, 2013, 09:31
Peyman
Hi diamondx
could you explain more? How can i empty the small tubes? because after meshing, the small tubes will be filled.
my block scheme is similar to yours, but the mesh is bad.
thanks in advance
Old   August 5, 2013, 10:26
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
If you dont need mesh inside tube just delete blocks.
diamondx likes this.
Far is offline   Reply With Quote
Old   August 5, 2013, 10:57
Peyman
okay, thank you far
Old   August 5, 2013, 11:05
Peyman
Hi, Is it correct?
Old   August 5, 2013, 11:39
diamondx's Avatar
Ghazlani M. Ali
it's correct just play with the edge now, "spline"... i am a bit busy here, i will came back to it later on this day, sorry about that
Regards,
Ali
Old   August 5, 2013, 12:01
Far
Sijal
Create o-grid around these small pipes.
Old   August 5, 2013, 15:30
Peyman
okay far, i will try
thanks diamondx, what do you mean about "play with the edge"?
around of the tubes??
Old   August 6, 2013, 10:26
Peyman
If we have further tubes in cylinder (like this picture), Can i mesh the model with this blocking scheme (O-grid block)?
I would be grateful if you can answer this question.
Old   August 6, 2013, 11:39
diamondx's Avatar
Ghazlani M. Ali
By playing with edge i meant, blocking -» edit edge -» split edge using spline
Now for you second geometry, that is two much... I can't really answer your question. You need to find a pattern for that , how did you create that pattern at the first place ?
Regards,
Ali
Old   August 6, 2013, 15:27
Peyman
in fact this model is the inlet part of a shell and tube heat exchanger with triangular tube arrangement (Between tubesheet and first baffle).
Old   August 8, 2013, 08:01
Peyman
Is it possible to implement this scheme for the model?
thanks.
Far likes this.
Old   January 20, 2014, 05:08
mistigh
mistigh is on a distinguished road
Hi guys,
i am newbie about icem cfd and still try to improve my meshing skills.According to Ali's grid i tried to make one,i cant delete blocks inside the holes tho.I'm in trouble finding where my mistakes are.Probably splitting block or not.Just need a few more hands guys.Thanks in advance.
http://imagizer.imageshack.us/v2/800...0/822/bvqq.jpg
mistigh is offline   Reply With Quote
Old   January 20, 2014, 17:36
diamondx's Avatar
Ghazlani M. Ali
Did you figure out the problem ?
Regards,
Ali
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
Turbulent flow in a cylinder pipe SeRGeiSarov Main CFD Forum 0 March 25, 2010 13:20
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
