August 4, 2013, 12:47 |
Creating an external shell
Argyrios Stouras
Hello guys,
I have an .igs model of a vertical axis wind turbine and I want to split each blade in order to create an external shell covering an internal core. In Ansys DM is inserted as a solid body and I had an idea to create a surface from one of the finishing faces of each blade (or a line from the edges) create an inward offset line and extend it to the other side to create an internal volume and therefore a body in an other body. The problem is that offset command doesn't allow to select any kind of generated lines from the faces. Should I go manually and create a rough polyline out of the face and go with it or there is an other way in order to have better, automated and more refined results? Sorry for any kind of bad terminology but I now started to use Ansys. |
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 15:33 |
[ICEM] Error in creating prism layers on an external flow geometry | zkittur | ANSYS Meshing & Geometry | 2 | June 5, 2017 14:47 |
CGNS Compiling | Diego | Main CFD Forum | 17 | December 21, 2014 01:40 |
Instalation on ubuntu 710 | basilwatson | OpenFOAM Installation | 17 | March 16, 2012 20:16 |
Problem in running ICEM grid in Openfoam | Tarak | OpenFOAM | 6 | September 9, 2011 17:51 |
