[BladeModeler] How to understand the modeling concept in blade modeler
Like Tree6Likes
Old   August 5, 2013, 06:41
Default How to understand the modeling concept in blade modeler
Devesh Kumar Singh
devesh is on a distinguished road
I am trying to use Ansys bladegen for generatinng the turbomachinary blade. I am not able to get any tutorials to understand the ways to use it. please suggest?
devesh is offline   Reply With Quote
Old   August 5, 2013, 07:48
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
I have some material on it. Send email id.
Far is offline   Reply With Quote
Old   August 6, 2013, 02:59
Devesh Kumar Singh
Thanks
my email id deveshks11@gmail.com.
regards.
Old   September 6, 2013, 17:22
Default Bladegen vs Blademodeler
Ontario
ranpreetbhatia is on a distinguished road
hey guys,
I am pretty confused about both these applications (I mean Bladegen and Blademodeler). Are both of these used for modelling blades? I am trying to obtain 3d models for some blades I have designed.
I have information like chord, axial chord, span, stagger, alpha, beta, etc at 3 locations (thats root, mean and tip). But, I am not sure how to proceed with the blade modelling, all I need is the coordinates for root and tip airfoil (or may be mean as well).
Is there any way, I can get some tutorials on using bladegen or blademodeler to obtain blade profile by provide the above said parameters (thats chord, axial chord, span, stagger, alpha, beta, etc).
Any help or advice would be appreciated.
Regards
Ranpreet B
ranpreetbhatia is offline   Reply With Quote
Old   October 3, 2013, 07:38
Default Help please
Hassan Adel
hassan1201 is on a distinguished road
Help me please i can't make flow path around Axial blade and every time Error
Error: The meridional plane placement is not correct.
Context: ansFClientBMBladeDesign::Execute FlowPath1
my mail: haelsheshtawy@gmail.com
hassan1201 is offline   Reply With Quote
Old   October 3, 2013, 10:24
Far
Sijal
are you using blade modeller?
hassan1201 likes this.
Old   October 3, 2013, 10:34
Hassan Adel
yes i use blade modeler, import point and extrud the blade, and try to make path flow, Plz any help
Old   October 3, 2013, 10:37
Hassan Adel
Every time this error appears, when make flow path
Old   October 3, 2013, 10:50
Hassan Adel
Dear Sijal Ahmed Memon
Please, can you help me?
Old   October 3, 2013, 11:14
Far
Sijal
Do that in turbogrid or design modeller and then use blade editor/blade modeller tool
Old   October 3, 2013, 11:44
Hassan Adel
I had used design modeler for model the blade, after that I used blade editor to make flow path, Can i send the File to you on your email to check out?
Old   October 3, 2013, 12:01
Hassan Adel
I have airfoil made in design modeler, and i need to make flow path for it.
this figure of my blade
Old   October 3, 2013, 13:51
Far
Sijal
you need hub and shroud surface. After that you need to do some operation, then you will be able to define flow path. You just need few more steps ...
Old   October 3, 2013, 13:58
Hassan Adel
I'd made hub, shroud, inlet, and exit lines after that defined it in flow path but
Error massage appears
Old   November 7, 2013, 10:04
osman pekmutlu
osmanpekmutlu is on a distinguished road
Dear Sijal Ahmed Memon,
Can you send these materials to my email too?
My email id is osmanpekmutlu@gmail.com.
Thanks a lot.
osmanpekmutlu is offline   Reply With Quote
Old   December 10, 2013, 14:38
Default Blade modeler
  #16
Muratoglu
Muratoglu is on a distinguished road
Hi guys! I am new in the blade modeler and try to design a horizontal axis wind/hydro turbine. I think, designing the blade in blade modeler will be better than BladeGen. I need some documentation about blademodeler. My e-mail is: abdmuratoglu@gmail.com
Regards
Muratoglu is offline   Reply With Quote
Old   May 10, 2014, 04:06
Adem
kd_adem is on a distinguished road
Is it possible to get the material also for me. My e-mail address is: kdadem@gmail.com
Thank you very much Far and Muratoglu.
Last edited by kd_adem; May 22, 2014 at 06:18. Reason: Problem with the e-mal address
kd_adem is offline   Reply With Quote
Old   May 19, 2014, 14:12
Nick foxx
enzo887 is on a distinguished road
please forward it to me as well
androides.gr@gmail.com
enzo887 is offline   Reply With Quote
Old   May 19, 2014, 14:27
Ontario
Send it to me as well, if you dont mind.
Thanks in Advance
My email address is ranpreetbhatia@gmail.com
Old   May 27, 2014, 12:46
majid
majidpc is on a distinguished road
And me
m_najafpour@aim.com
majidpc is offline   Reply With Quote
Compressor Blade Analysis in Ansys CFX LynchMobster47 Main CFD Forum 0 April 10, 2012 22:43
[ICEM] 3D turbine blade modeling ShaneStan ANSYS Meshing & Geometry 49 December 4, 2011 13:48
Inlet Flow Velocity or pressure gradient - modeling of a Wind Turbine Blade case LittleBart Main CFD Forum 5 January 10, 2011 15:07
Basic Concept of Secondary flow in Compressor Blade Saima Main CFD Forum 1 November 23, 2010 07:10
Modeling Terrain in Design Modeler Will C ANSYS 0 February 26, 2010 18:13
