boundary layer development in gambit
Like Tree1Likes
  • 1 Post By -mAx-
Old   September 19, 2013, 04:10
Exclamation boundary layer development in gambit
maaz ahmad
maaz is on a distinguished road
i am working on wind effects on high rise building..i have to develop boundary layer along the wall on computational domain and building as well...gambit is showing message..initialization failed...with error code 1...i am unable to resolve this..kindly help me...
maaz is offline   Reply With Quote
Old   September 19, 2013, 05:16
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
more info please, with pictures
maaz likes this.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   September 20, 2013, 01:25
Default kindly help me out...
maaz ahmad
hi max..
i have to develop boundary layer on the ground and building surface..i am attaching pics here,, kindly look into it.. and help me ..out..thanx
Old   September 20, 2013, 01:33
-mAx-'s Avatar
Maxime Perelli
then pick surfaces of ground and building...
take care of first cell's height.
If you give an exotic value, then the BL propagation may fail
http://aerojet.engr.ucdavis.edu/gamb..._blayer_create
Old   September 21, 2013, 03:19
maaz ahmad
max thanx for your response...i have changed the geometry of computational domain to resolve the error..
Old   September 23, 2013, 03:33
maaz ahmad
max.. can you tell me about the aspect ratio for boundary layer ....
Old   September 23, 2013, 03:49
-mAx-'s Avatar
Maxime Perelli
http://aerojet.engr.ucdavis.edu/gamb...spec_algorithm
with aspect ratio algorithm, you don't have fixed first cell' s height.
Old   September 23, 2013, 23:32
maaz ahmad
no dear the thing i wanna ask is that when we examine the mesh and in the option of quality type we click aspect ratio , then what is the range of this value that is best suited for a mesh.
Old   September 24, 2013, 01:34
-mAx-'s Avatar
Maxime Perelli
from Help: "However, a general rule of thumb is to avoid aspect ratios in excess of 5:1. " --> http://aerojet.engr.ucdavis.edu/flue...ug/node155.htm
I would simply load the mesh in the solver and run a check mesh
Old   September 27, 2013, 02:51
Default problem in udf for velocity proflie
maaz ahmad
vprofile.c UDF for specifying steady-state velocity profile boundary condition
************************************************** **********************/ #include "udf.h"
DEFINE_PROFILE(inlet_x_velocity, thread, position)
real x[ND_ND]; /* this will hold the position vector */
real y; face_t f;
begin_f_loop(f, thread) { F_CENTROID(x,f,thread); y = x[1];
F_PROFILE(f, thread, position) = (10 + y/12.5)*cos(5.0/180.*3.1415927); }
end_f_loop(f, thread) }
DEFINE_PROFILE(inlet_y_velocity, thread, position)
/* insert your own code here*/
max....in this udf while defining
can we use log formula also, if yes then please explain it for me.....
Old   September 27, 2013, 04:05
ghost82's Avatar
Rick
ghost82 will become famous soon enough
real y; face_t f;
Hi maaz,
see attached picture from udf manual.
Daniele
ghost82 is offline   Reply With Quote
Questions about Boundary Layer Thickness and Turbulence Models famerfamer STAR-CCM+ 3 July 12, 2012 09:47
Boundary Layer roughness/ low reynolds wall treatment Luigi_ STAR-CCM+ 1 March 14, 2012 08:40
Boundary layer meshing problem in Gambit Crystal FLUENT 0 June 12, 2009 20:58
Gambit Boundary Layer Anand FLUENT 0 January 29, 2009 15:13
help for Gambit: 2 edges + 1 boundary layer Peter FLUENT 0 August 9, 2002 19:41
