October 9, 2013, 13:14 |
3D wing meshing
Dinh
Rep Power: 12 |
hi everybody,
I try to mesh a finite wing ( NACA 2415 airfoil), I mesh with and without boundary layer but when I check the skewness it has high skewness value (>0.9) in the trailing edge in both cases. Coulde you give me a solution for these cases Im doing, Thax in advance . |
October 18, 2013, 10:40 |
Dinh
Rep Power: 12 |
October 23, 2013, 13:46 |
Dinh
Rep Power: 12 |
I'm trying to mesh a 3D wing for validation, my airfoil is FX63-137, I've used Gambit but I found out that it was easy to mesh 2D but 3D , so I'm learning to use DesignModeler.
I have a problem that I can know how to block this wing in a domain, and how to creat a domain with all quad mesh. Could you give me some advices or some tutorial for me to learn? Yesterday, I made a mesh but it is a tet mesh, and I checked the skewness is <0.9, is it ok for my calculation? Do i need to check other quality? My mesh: http://www.mediafire.com/download/ye..._treatment.msh My CAD file : http://www.mediafire.com/?dewcpf98qwmi5o3 Finally, thanks for your helps |
October 28, 2013, 13:48 |
[ICEM] Meshing a wing with a wind gallery | crostolo | ANSYS Meshing & Geometry | 0 | July 25, 2013 13:13 |
[ICEM] Meshing of a closed wing | Lukas_ZH | ANSYS Meshing & Geometry | 34 | July 6, 2012 07:15 |
[GAMBIT] Meshing of flipper wing | dv.darshan | ANSYS Meshing & Geometry | 9 | May 21, 2012 01:38 |
[snappyHexMesh] Meshing 3D wing (hydrofoil) fails | klausb | OpenFOAM Meshing & Mesh Conversion | 0 | December 28, 2011 14:26 |
Wing meshing help...... | ACER | Main CFD Forum | 0 | January 31, 2011 18:20 |
