[ICEM] Tagging Faces of block or converting faces of block into surface
Old   October 19, 2013, 10:04
Default Tagging Faces of block or converting faces of block into surface
Ashwani
AshwaniAssam is on a distinguished road
Dear all,
Is it possible to tag the faces of the blocks which are lying on the boundaries. Or, is it possible to convert the faces of the block into surfaces.
So, that using create part I can name them.
I need to read the mesh file zone wise. And my zones will be the blocks created.
Please if any one can help.
AshwaniAssam is offline   Reply With Quote
Old   October 19, 2013, 14:49
Ashwani
It feels that in earlier version of ANSYS there was some bug while writing cgns file. In ANSYS14 ICEMCFD, I am able to have a single defined surface facing two or more block faces. My code reads the cgns file properly.
But still, I have problem in having a proper interface tagging. My code is showing only 3 boundaries for some zone for the 3d cylinder meshing. I am using the 2d-3d extruding mesh tutorial shown on Youtube.
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[blockMesh] Mixer mesh - negative volume problem jadtwo OpenFOAM Meshing & Mesh Conversion 2 November 6, 2014 16:37
[blockMesh] FOAM FATAL ERROR: Inconsistent number of faces blockMesh::createMergeList() line 193 Hengel OpenFOAM Meshing & Mesh Conversion 0 September 15, 2010 08:34
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
