November 9, 2013, 23:57 |
Ogrid not successful
clocter
Rep Power: 14 |
All,
I am having problems running an ogrid through pipes - error msg - ogrid not successful. My geometry is as follows- Inlet-splits into a loop-combines again-Outlet ( 2 Y shapes inverted) I generated the blocking by extruding the faces and when it splits into a loop and then merge vertices when they combine again. When i try applying an ogrid it is not successful. I tried renumbering, resetting ijk of the blocks - its still not working. Is it because the blocking was separate and the ogrid does not see connectivity? Thanks |
November 10, 2013, 03:39 |
clocter
Rep Power: 14 |
Thanks for the reply.
So are you suggesting that I completely associate all the edges/curves and then run the ogrid through the pipes? I will try it out, but I thought association is not related to generating an ogrid? Regards DJ |
[ICEM] ogrid to h-grid connection | Teradil | ANSYS Meshing & Geometry | 2 | March 4, 2013 04:59 |
[ICEM] 2D Airfoil Meshing (Ogrid) | mrenergy | ANSYS Meshing & Geometry | 1 | December 22, 2012 11:45 |
[ICEM] unwanted pre-mesh inflation around Ogrid | macfly | ANSYS Meshing & Geometry | 7 | September 25, 2012 09:41 |
y+ Value & Aspect Ratio {Wind Tunnel Model} | FabioT | ANSYS Meshing & Geometry | 18 | October 5, 2010 15:00 |
ogrid in ogrid | susan | CFX | 4 | December 20, 2007 05:58 |
