[ICEM] importing geometry from coordinate file
Old   December 7, 2013, 07:11
Default importing geometry from coordinate file
Daniel
Daniel_Khazaei will become famous soon enough
Hi guys
I am trying to import a geometry from a coordinate file. The geometry is attached and the curve equation is:
y = A*sin(x/(L*b))
L=30 cm, A=0.002 and b=0.25
also I have attached the coordinate file that I have created so far based on the above equation.
The problem is when I import the data file into ICEM, nothing happens. So i think something is wrong with data file. The coordinate file is also attached.
I have tried an airfoil coordinate file and it worked.
any help would be appreciated.
regards
Daniel_Khazaei is offline   Reply With Quote
Old   December 9, 2013, 02:10
muhammad hussain
hussain_2723 is on a distinguished road
your formate of the file you want to upload is not the right one try to use the following formate in the JPG bellow.Capture.JPG
hussain_2723 is offline   Reply With Quote
Old   December 9, 2013, 04:19
Daniel
Originally Posted by hussain_2723 View Post
your formate of the file you want to upload is not the right one try to use the following formate in the JPG bellow.Attachment 27235
well I have found a workaround for my problem. I have imported my coordinate file into the design Modeler by 3D curve feature. In design Modeler I have created my geometry. Then I have used the geometry in ICEM.
thanks for the answer.
regards
[Other] OpenFOAM Installation for navalFoam sachinlb OpenFOAM Community Contributions 22 July 28, 2017 05:26
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 03:23
[swak4Foam] funkySetFields compilation error tayo OpenFOAM Community Contributions 39 December 3, 2012 05:18
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
