December 17, 2013, 11:21 |
Mesh Nibbling desipte refinement
Matthew Rich
Rep Power: 12 |
Hello CFD community!!!
Been messing with this model for a while now and for the most part I am happy with it. My qualm is with this mesh nibbling where for no real apparent reason the surface and line curves are not respected in a minute location. The refinement is should be sufficient for the geometry as seen in the pics below. Any ideas? I would fix manually but I have this phenomena happening in a few areas. thanks in advance |
December 17, 2013, 17:18 |
Rep Power: 24 |
I also experienced this problem every once in a while. It is helpful to set curve sizes on the boundary curves. You may also try to reduce model tolerances under settings -> model.
December 18, 2013, 16:01 |
Matthew Rich
Rep Power: 12 |
Dropped the model tolerance and it worked beautifully!!!
Many thanks kad!!!!! |
[snappyHexMesh] snappyHexMesh Boundary Layer at Corner | panpanzhong | OpenFOAM Meshing & Mesh Conversion | 5 | July 3, 2018 05:53 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[snappyHexMesh] snapEdge - failure | Tobi | OpenFOAM Meshing & Mesh Conversion | 33 | March 18, 2014 03:58 |
[snappyHexMesh] Snapping not enough (even with surfaceFeatureExtract) | ironclad | OpenFOAM Meshing & Mesh Conversion | 1 | November 8, 2013 02:58 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
