[ICEM] What does 'Split Internal Wall' means?
Old   February 10, 2014, 23:09
Default What does 'Split Internal Wall' means?
ant
antornado is on a distinguished road
Hi community,
I am using ICEM to mesh compressor blades and I would like to ask what does the 'Split internal wall' option under the 'edit mesh' tab do?
I'm using tetra mesh and I have a surface that separates 2 different fluid zones (I labelled as solid and fluid). I want to create 2 surfaces so that I can merge them together as an 'interface' in fluent.
Is the 'split internal wall' option suitable? I tried the option and it resulted in 'building grid: aborted due to critical error' in fluent.
Please advise, thank you!
antornado is offline   Reply With Quote
Enhanced Wall Treatment paduchev FLUENT 24 January 8, 2018 11:55
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 12:11
volume flow through internal hole in the wall wouter OpenFOAM 4 February 14, 2011 07:36
Influece of wall velocity in the main flow marvin CFX 0 March 22, 2008 02:05
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
