[Workbench] High Cambered Aerofoil Meshing Problem (Workbench)
Old   February 16, 2014, 05:39
Default High Cambered Aerofoil Meshing Problem (Workbench)
Eleanor Rajaratnam
elebelly is on a distinguished road
Hi! I've been following this tutorial:
https://confluence.cornell.edu/displ...Airfoil+-+Mesh
for creating my mesh around this specific aerofoil, however due to it's high camber and asymmetry instead of using the Mapped Face meshing technique I applied the Multizone Meshing one where the following are my constraints:
Mapped mesh type: Hexa
Free mesh type: Not Allowed
However the following image shows the discrepancies from just below the bottom edge of the aerofoil to the centre line x-axis. How can I resolve this and any another of the errors that have appeared (such as overlapping geometry)?
Dropbox of files: https://db.tt/VIRzWkbe
Any help is truly appreciated!
Kind regards,
Ele
elebelly is offline   Reply With Quote
Old   February 16, 2014, 06:14
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Here is a thread about the same topic.
http://www.cfd-online.com/Forums/flu...ease-help.html
This might have been hard to find because of the "vague" title.
flotus1 is offline   Reply With Quote
Old   February 16, 2014, 06:59
Eleanor Rajaratnam
Hi, for the geometry setup I used this particular tutorial: http://www.mne.psu.edu/cimbala/Learn...ial_Airfoil.pd
Which I believe follows the 'Form new part' as you suggested in that thread?
When you suggested to 'merge' the two sections how would I go about that?
Thank you for your reply!!
Old   February 16, 2014, 07:10
flotus1's Avatar
Alex
I had a boolean operation in mind.
Old   February 16, 2014, 07:20
Eleanor Rajaratnam
I'm really new to this so please could you explain in a little more detail?
The only boolean command I used during Design Modeler was to remove the airfoil from the fluid volume.
Thanks once again.
Old   February 16, 2014, 07:41
flotus1's Avatar
Alex
Then you already know how to do it.
Only this time, you have to unite the face that is causing the distorted mesh with the adjacent face. There is even a picture in the linked thread.
Please note that in the cited thread a completely different approach was chosen in the end.
Old   February 16, 2014, 08:04
Eleanor Rajaratnam
I have united them using a boolean however when I ten try to open it for meshing I am only left with the bottom left quadrant and the aerofoil! (The other 3 quadrants have disappeared even though they still appear in design modeler)
Old   February 16, 2014, 08:20
flotus1's Avatar
Alex
Post a screenshot of the model tree in Design Modeler before you proceed to the meshing application.
Old   February 16, 2014, 08:44
Eleanor Rajaratnam
Thank you.
Old   February 16, 2014, 09:03
flotus1's Avatar
Alex
My bad.
I forgot to mention that we need screenshots where we actually see the relevant parts of the model tree.
Expand the geometry section and post at least 2 screens where you clicked on each of the 2 "parts" so we can see its details in the details view.
Old   February 16, 2014, 09:23
Eleanor Rajaratnam
Ah sorry about that, is this good enough? I deleted the boolean to show you the two specific parts.
Old   February 16, 2014, 10:04
flotus1's Avatar
Alex
I dont feel like we are going to solve the problem this way. For example, I have no idea where the line body is coming from.
I recommend you start over again and use the approach outlined in the linked thread ("bottum up", separate sketch for each of the four planes).
Problem with querying the meshing database in CFX-Pre ashtonJ CFX 18 April 18, 2023 23:49
ANSYS 13 X64 Workbench problem: "Could not connect to local server" ggc ANSYS 38 October 7, 2018 17:11
[DesignModeler] Meshing Aerofoil Workbench (Design Modeller) elebelly ANSYS Meshing & Geometry 2 February 15, 2014 14:56
Meshing locks workbench window. andy2o CFX 0 February 1, 2008 05:01
GAMBIT meshing problem Gauthier Lambert Main CFD Forum 1 August 3, 2000 09:22
