[ICEM] Creating unstructured mesh and setting mesh sizes |
February 25, 2014, 22:23 |
Sam
Hello everyone
I am currently working on generating a 3D unstructured mesh for the impeller and diffuser below. I would first like to generate an octree mesh followed by a delaunay mesh. I would like to seek advise from any experts here on how I should go about setting my mesh sizes, such as scale factor, max. element, min size limit and refinement number etc. Should I also enable prism for all the walls at part mesh setup? I tried generating an unstructured mesh with all default settings and I get the following warning message. 'The mesh size appears to be inadequate to represent the geometry. Do you want to run with autosizing?' Any advise / tips are appreciated. Thanks in advance! |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
