[GAMBIT] Problem with boundary layer - high skewness |
February 26, 2014, 08:15 |
Oleg
Rep Power: 12 |
Hello, everyone! I'm asking for help with a GAMBIT problem. Trying to create boundary layer on volume but it results with high skewness.
I don't think it's possible to slice this volume into smaller parts. (Actually it is a part of much more complex case). Trying different surface mesh schemes didn't help as well as trying to change defaults for BLAYER. What I cannot understand is why it doesn't preserve thickness of boundary layer, because even if I managed to reduce skewness <0,97 a layer is still too thin in some areas. I'm out of ideas, please, suggest something... |
February 27, 2014, 01:28 |
Maxime Perelli
Rep Power: 41 |
yoou have to be sure that your problem comes from the BL.
For that, delete the BL and mesh your volume. As I see you your surface mesh, I suppose you want to mesh your volume with hexa. With such a topology, you won't be able. You have to split your volume. check this tutorial: https://www.sharcnet.ca/Software/Gam...guide/tg03.htm
In memory of my friend Hervé: CFD engineer & freerider |
February 27, 2014, 07:36 |
Oleg
Rep Power: 12 |
Thank you very much for this tutorial. I somehow missed it.
I don't want to mesh this volume with hexa, I only want a hex BL. However now I see it's unlikely to get a good layer without splitting the volume. |
February 28, 2014, 00:25 |
Maxime Perelli
Rep Power: 41 |
Ok if you don't want hexa volume, mesh your surface mesh with tri elements.
Your BL will be prismatic. It should fix your problem. Then mesh your volume with tet/hexcore (core of your volume with hexaeders)
February 28, 2014, 07:34 |
Oleg
Rep Power: 12 |
I tried triangular meshing and it didn't help. I fiured out that increasing mesh density and thickening BL rows can partly resolve the problem. Of course, the right way is to split the volume but I don't have much time so I'll put up wth it, thank you again.
boundary layer, gambit 2.3.16, skewness |
High aspect ratio mesh problem for flat plate boundary layer | sam1364 | OpenFOAM | 3 | May 14, 2020 11:11 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
Automobile aero ground boundary layer OR simpleFoam/GAMG and high aspect ratio cells | kyle | OpenFOAM Running, Solving & CFD | 4 | January 4, 2011 11:17 |
[snappyHexMesh] Boundary layer generation problems | ivan_cozza | OpenFOAM Meshing & Mesh Conversion | 0 | October 6, 2010 13:47 |
