[ICEM] Problem with using the Delaunay volume mesh method
Like Tree2Likes
  • 1 Post By manahara
  • 1 Post By kad
Old   March 13, 2014, 07:58
Default Problem with using the Delaunay volume mesh method
Manahara Manatunga
manahara is on a distinguished road
Hello Everyone,
I have been trying to create an unstructured mesh around a Formula 1 model. I have tried using the Delaunay method to create a volume mesh around the car but the volume mesh created exceeds my defined test space.
The issue is indicated in these photos..
I don't seem to understand why this happens. There might me something that I am doing wrong in my set up process so I will list the steps that I took in creating the mesh.
1. I imported the geometry, Then created the Inlet, outlet and Farfield parts. Created a body called Fluid.
2. I used the global mesh setup to define my max element size to be 4. (The test space is 10 by 20 by 10)
3. In shell mesh setup, I chose All tri and Patch Independent.
4. In volume mesh set up, selections are tetra/mixed, quick (Delaunay) and scaling factor:1.2
5. In part mesh setup, I defined the max element size on the car to be 0.05 and left all other parameters to be 0.
6. Compute mesh; surface mesh and generated a surface mesh. (image below)
7. Finally Compute mesh> Volume mesh I chose tetra/mixed, quick (delaunay) Volume part name: Inherited
I would be extremely grateful if I someone can show me where I am going wrong.
Thank you very much in advance!
Best Regards,
Manahara
manahara is offline   Reply With Quote
Old   March 13, 2014, 10:48
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Originally Posted by manahara View Post
Hello Everyone,
Best Regards,
Manahara
reduce the max size and try again...
Far is offline   Reply With Quote
Old   March 14, 2014, 12:22
Manahara Manatunga
Hi Far, Thank you for your reply! I tried reducing the max element size on Global Mesh Setup to 1 and then to 0.6. None of which worked. When computing the volume mesh, the process terminates and shows an error message saying, 'tri-to-tet mesh terminated prematurely'.
Any ideas as to why this is happening?
Old   March 14, 2014, 12:47
Far
Sijal
It happens some times when i try to create delaunay mesh. I dont know why, but i usually play with size
Old   March 14, 2014, 13:49
Far
Sijal
same problem i had in formula one meshing : http://www.cfd-online.com/Forums/ans...ula-one-6.html
Old   March 15, 2014, 16:11
Manahara Manatunga
Thank you very much! I am going to try a octree mesh, then delete the volumes and create a delaunay rather than from surface mesh to delaunay. Hopefully it works!
Dronzer likes this.
Old   March 17, 2014, 14:17
Julio Mendez
juliom is on a distinguished road
Send a message via Skype™ to juliom
THis las approach is better, and I usually do this approach!!! first octree and then Delaunay...
The same if you use Shell meshin with patch independent and then delaunay!!! is the same thing!!
juliom is offline   Reply With Quote
Old   December 11, 2014, 13:37
Chris_321's Avatar
Christian
Chris_321 is on a distinguished road
I have the same problem.
Can someone explain me how to delete the volume mesh?
Does it work if i hide the surface and show the volumes and delete all visible mesh parts?
Chris_321 is offline   Reply With Quote
Old   December 13, 2014, 15:26
kad
kad will become famous soon enoughkad will become famous soon enough
There is actually a icon for this in the selection tool bar. Go to "delete elements" and the then use the very right button in selection tool bar.
Dronzer likes this.
kad is offline   Reply With Quote
Old   December 21, 2014, 18:16
Chris_321's Avatar
Christian
1) Octree meshing
2) Saving Project
3) Delete Volume
4) Run delauney
will not fit it for me
Old   December 25, 2014, 13:54
Far
Sijal
what is the problem. This procedure is pretty quick to produce high quality meshes
Old   December 25, 2014, 21:52
Manahara Manatunga
Hey, sometimes defining the material body helps to avoid this 'mesh leak'.
Old   December 25, 2014, 21:54
Manahara Manatunga
Oh and also do not forget to run the geom topology check for holes.
delaunay, icem cfd 13.0, tetra mesh, unstructured mesh
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
[blockMesh] Mixer mesh - negative volume problem jadtwo OpenFOAM Meshing & Mesh Conversion 2 November 6, 2014 16:37
[ICEM] volume mesh leaking out of the surface, in a multi zone problem premchandpendota ANSYS Meshing & Geometry 6 July 31, 2012 01:36
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
