March 19, 2014, 11:42 |
Delaunay Problem
Edoardo
Rep Power: 12 |
Dear user,
I am relatively new to ICEM. My project is about meshing a wind turbine: it consists of a spherical flow field around that contains the whole assembly, with a cylindrical one around the rotor only. I meshed the assembly with robust octree as first. This meshed the geometry fine, expect for some little element on the trailing edge which I manually moved in the correct position. To move them I deleted all the volume elements and then moved them. Then to reconstruct the volume mesh from the surface mesh I used the quick Delaunay. The mesh botained mesh, however, isn't what I would like: ICEM makes a block around my domain and the element are very weird. I will put a picture of it. If anyone has an input it would be great! Thanks a lot! Last edited by Far; March 20, 2014 at 11:01. Reason: Was just adding image at the end of the post to clarify the problem |
delaunay, mesh, mesh problem |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
