[ANSYS Meshing] Meshing a Y-junction
Like Tree1Likes
  • 1 Post By cfd^2
Old   April 22, 2014, 10:23
Default Meshing a Y-junction
cfd^2
cfd^2 is on a distinguished road
Does anyone know how to create an hexa mesh in a circular Y-junction in ANSYS meshing? I tried multizone, but if fails...
Regards.
shaimaazohair likes this.
cfd^2 is offline   Reply With Quote
Old   May 5, 2014, 05:27
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
The best way is to use ICEM, there are a lot of topics explaining the procedure step by step to generate a hexa mesh in a T/Y-junction.
Originally Posted by Far View Post
Just brief steps :
1. Create main block
2. split at the junction and then two splits on the two sides of small pipe and perpendicular to bigger pipe
3. delete two blocks on right and left of the small pipe
4. Make associations
5. snap vertices.
6. make o-grid inside the small small upto the large pipe's bottom. Select two extreme faces.
7. Make the O-grid for the larger pipe and again select the respective end faces.
8. go to edge mesh parameters and update all sizes and go to second tab and give size 2 and apply. Keep on applying until mesh size is at-least 20000 hexas
9.Check premesh.
10. One horizontal split in the large pipe.
11. Play with vertices location panel to adjust the blocking to higher quality.
Gweher is offline   Reply With Quote
[ICEM] T Junction Meshing using ICEM CFD selvam2487 ANSYS Meshing & Geometry 21 July 25, 2017 12:04
[ICEM] Help needed regarding meshing of T junction selvam2487 ANSYS Meshing & Geometry 0 February 25, 2013 04:27
[ICEM] Solid wall meshing in T junction selvam2487 ANSYS Meshing & Geometry 16 January 3, 2013 09:43
T junction - meshing wall zone in Gambit John FLUENT 3 August 29, 2005 10:09
