April 26, 2014, 06:14 |
BladeGen Data Import Wizard
dear all
I'm trying to import geometry into BladeGen using Data Import Wizard. During the process I have an error in "Step 4-Blade Geometry, Edit/Confirm Blade Loops". How can I the the error in this step? 'Error: Selected Item is not available. Please complete ...' |
August 5, 2014, 21:46 |
Ahmad
Rep Power: 11 |
August 11, 2014, 07:46 |
Rep Power: 18 |
Do you have in Step2 all marks as green tag? How many blade layers do you have?
August 11, 2014, 19:18 |
Ahmad
Rep Power: 11 |
Hi Ludvik thanks for your response. Yes I have everything in green. It turns out that I had two bad point in my meridonal contours but I fixed them. However, now I have a new problem! The data import wizard crashes when I complete the steps and hit the complete button. I have 19 blade layers, any ideas would be so much appreciated!
August 12, 2014, 06:44 |
Rep Power: 18 |
Try export the blade without any LE/TE elliptic ratio.
May 27, 2015, 13:39 |
#7 | |
beyonder
Rep Power: 11 |
July 11, 2016, 11:07 |
Brett
Hey guys im having this problem.
How did you fix the issues with Step 4? Brett |
July 11, 2016, 11:11 |
Brett
August 28, 2018, 15:07 |
Charles
Rep Power: 7 |
This is my first post, so I apologize for missing any information in my request. I am having the same problem on Step 4. I have been able to select two curves each defining the shroud and hub curves. I have also selected a series of curves to define the blade objects. One of the objects is four curves (to make a closed loop) and the other is 9 curves (again, to make a closed loop). For some reason, the original .iges file I am working with imported one of the blade loops as more than four curves. This is shown in the attached image as the series of points and lines near the lower right hand corner of the GUI. The blade object with four curves is orthogonal to the image and is not shown. Specifically, my question is does the blade profile need to be defined by four curves? Secondly, if this is the case, can these lines easily be combined? Thirdly, should each blade object/loop be selected separately in step 2? I am not sure if this is an option or not, since all the objects seem to be lumped into one curve set. Thanks in advance for any help offered! -Charles |
[Other] [DesignModeler] import data XYZ | zelito | ANSYS Meshing & Geometry | 0 | December 15, 2009 14:48 |
Import validation data to CFX Post | Vattenkraft | CFX | 0 | November 26, 2009 19:55 |
import spline data format | Chris | Siemens | 0 | March 30, 2005 13:09 |
I-DEAS CAD data import with boundary conditions | Yunus | Siemens | 1 | June 1, 2001 10:04 |
