[ICEM] Meshing a Bifurcation using Hexa
Like Tree14Likes
Old   May 7, 2014, 12:37
Default Meshing a Bifurcation using Hexa
Daniel
Daniel_Khazaei will become famous soon enough
Hello to all
I am trying to mesh a bifurcation geometry. I have managed to generate an unstructured mesh using Tetra/Mixed method.
However I am wondering if it possible to get a mesh like this one in ICEM using usual blocking?
Thanks in advance
D. Khazaei
Daniel_Khazaei is offline   Reply With Quote
Old   May 7, 2014, 12:56
kad
kad will become famous soon enoughkad will become famous soon enough
Check out Simon's Tipps and Tricks documentation. It has a detailed description for blocking a very similar geometry (fork).
Daniel_Khazaei likes this.
kad is offline   Reply With Quote
Old   May 7, 2014, 13:02
Daniel
Would please provide the link?
Best wishes
Old   May 7, 2014, 13:07
Javi
FJSJ is on a distinguished road
Hi Daniel,
I wondered the same thing few months ago, and as Kad said, simon'tips has two approaches.
Here the link (see 85 & 86 slides)
Simon's tip
FJSJ is offline   Reply With Quote
Old   May 7, 2014, 13:13
Daniel
Originally Posted by FJSJ View Post
Hi Daniel,
Simon's tip
Thank you both for your suggestions.
I will read this PDF and come back.
Old   May 7, 2014, 14:11
Daniel
I don't think that blocking produce high quality mesh for circular tube at bifurcation region.
This is how I want the mesh look like:
Old   May 7, 2014, 20:15
Daniel
I have tried to do the blocking as Simon suggested in his tips and tricks.
However, I don't know how to fix it:
Old   May 8, 2014, 05:14
Javi
Hi Daniel,
I´ve tried with a geometry similar to yours. The problem was the same, just the junction surface. Please, can you share your geom?
Old   May 8, 2014, 07:10
Daniel
Hi Daniel,
Of course...
Were you able to fix your problem?
Best wishes
Old   May 8, 2014, 08:15
kad
Please, can you share your geom (and blocking)?
Looks like a problem with associations. Check vertex and edge association. If these are correct associate faces manually to their corresponding surfaces.
Old   May 8, 2014, 08:22
Daniel
I have tried to manually associate faces to corresponding surfaces, but the problem is still there.
However, about vertex and edge association:
It is a CAD geometry and there are to many curves there.
Do you think that the sharp angle in my blocking strategy is responsible for this problem?
Old   May 8, 2014, 08:44
kad
The sharp angle could be a minor problem, but in general blocking should be doable. Your blocking looks not 100% okay in your last attachment. It looks like there are degenerated blocks near the sharp angle. But this could also be a matter of perspective.
Why don't you share your project? Would be much easier.
Old   May 8, 2014, 08:55
Daniel
I am trying to attach it here but the size is larger than the limit.
Now I am uploading the project on a another host.
Old   May 8, 2014, 09:01
Daniel
here is the full project:
http://www.rodfile.com/r86znlonj5zq
Old   May 8, 2014, 11:22
Javi
What is the password?
Old   May 8, 2014, 13:19
kad
After having a look at your project I must admit that our suggested blocking strategy is probably wrong. You can do it, but you will end up with some bad elements and run into trouble with ogrid creation (see att which is without ogrids).
Meanwhile I think I have understood the strategy in your posted pics. I will explain this later/tomorrow as I am going home now.
Old   May 8, 2014, 14:44
Daniel
Thank you very much.
I am eagerly waiting to hear from you.
Old   May 9, 2014, 08:44
kad
I have attached the generic blocking structure for your geometry. Now you have to apply to your geometry. If possible I would strongly suggest a geometry clean up in CAD. I tried it myself in Designmodeler. It somehow worked but destroyed the surface structure.
If blocking is to hard you can also try ANSYS Workbench CutCell meshing. I just started to work with it this week and it gave decent results in a short time. It is really not hard to handle if you are familiar with other meshing tools.
FJSJ and Daniel_Khazaei like this.
Old   May 9, 2014, 08:47
kad
Blocking attached. The .blk* (e.g. .blk3) show the progress of work.
Old   May 9, 2014, 08:56
Daniel
Thank you very much for the help man.
I will try to work this out.
[ICEM] Hexa meshing of impeller and diffuser assembly Nitin Dewangan ANSYS Meshing & Geometry 14 September 13, 2016 09:41
[ICEM] Hexa dominant meshing Pat84 ANSYS Meshing & Geometry 19 December 2, 2015 17:20
Wind tunnel hexa meshing in ICEM CFD 12.1 matheusguzella ANSYS Meshing & Geometry 1 March 14, 2011 16:14
Hexa Block meshes in ANSYS Meshing? siw ANSYS Meshing & Geometry 3 July 31, 2009 10:40
Hexa meshing or Tetra meshing??? NITIN DEWANGAN CFX 5 August 5, 2008 09:59
