[ICEM] Heat Exchanger
Like Tree1Likes
  • 1 Post By raghav
Old   May 13, 2014, 13:37
Default Heat Exchanger
Engineer
nnprashant is on a distinguished road
When creating baffles mesh gets distorted. How to mesh the inner pipe with baffles ?
Blocking strategies for inner pipe. Pipe should not be removed.
Thanks in advance
nnprashant is offline   Reply With Quote
Old   May 14, 2014, 04:09
Raghav
raghav is on a distinguished road
share me your geometry. will work out.
raghav is offline   Reply With Quote
Old   May 14, 2014, 13:25
Default Heat Exchanger Geometry
Engineer
I have attached the Heat Exchanger geometry. Please have a look.
Old   May 19, 2014, 01:19
Raghav
Please find below the blocking files for your geometry..
Old   May 19, 2014, 02:26
Thumbs up
praveen@cfd-online.com's Avatar
Praveen Kumar R
praveen@cfd-online.com is on a distinguished road
Hi Prashant,
You have done the blocking for the outer tube correctly. But you need one more O-grid to resolve the inner tube of heat exchanger (Similar to concentric tubes) and put these innermost blocks in a separate part in ICEM. Not in the same part (FLUID) as that of the outer block.
Its good you have used face interpolation to resolve baffles. One more suggestion. It is always good to create the boundary layer O-grid at last, after resolving all the geometry parts.
If I am not wrong, you are working on the assignment from the ICEM course of LearnCAx . I really appreciate your efforts in completing the task. Although it is a test or assignment, you can take help of our technical support team at any moment of your learning. We will be more than happy to help you in this regard.
Happy Learning !!!
Praveen Kumar R
praveen@cfd-online.com is offline   Reply With Quote
Old   May 19, 2014, 05:08
Default Heat_Exchanger with Baffles
Raghav
FYR..
Have placed the ICEM files in 2 separate zip files.
Roughly I gave mesh parameters. You can add BLs as per your requirement.
Regards,
Raghav
supoman likes this.
How to carry out 3D shell and Tube Heat Exchanger analysis in fluent medogalal FLUENT 3 December 30, 2015 04:28
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Macro Heat Exchanger not selecting (Please help!) zdeth FLUENT 2 September 11, 2012 13:52
UDF for Heat Exchanger model francois louw FLUENT 2 July 16, 2010 02:21
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
