[ANSYS Meshing] I have trouble in meshing the space of a hollow cylinder
Old   September 5, 2014, 18:40
Default I have trouble in meshing the space of a hollow cylinder
Zhuo
zaxfly is on a distinguished road
when I used workbench of ANSYS,I cannot mesh the space of my stuff. it's like a hollow cylinder(image), after generate mesh, I wanna get the grid inside the cylinder, not only the surface. can anyone told me how to solve it ?
zaxfly is offline   Reply With Quote
Old   September 9, 2014, 15:37
amin.z's Avatar
Amin
amin.z is on a distinguished road
Can you explain more? Do you want to mesh all of the cylinder? The surfaces and inner empty part?
amin.z is offline   Reply With Quote
Old   September 9, 2014, 18:37
Zhuo
Yes, exactly. I can just mesh the surface but do not know how to mesh the inner cylinder. I wanna know the method to mesh inside of a hollow stuff.Thank you!
Old   September 9, 2014, 23:26
amin.z's Avatar
Amin
Do you fill the inner empty space with material? Is the outer space solid and inner space fluid? As appear in the picture, I think you have only the solid part!
Old   September 13, 2014, 15:02
Zhuo
Yes, I can ONLY mesh the solid part. I do not know how to mesh the empty space. Do I need to fill the empty space with material? Cuz it is an empty space. In other words, the material is air.
Old   September 14, 2014, 07:02
amin.z's Avatar
Amin
Anything has influence in your analys must be model
If you want to do a cfd simulation the air must exist and meshed
But if you want to do a static analys you don't need air!
Old   September 23, 2014, 21:21
hwet is on a distinguished road
old times, i used to have this problem long ago when i was new to cfd. any place you want to mesh must be filled. if you fill the inner space with material only then it would be meshed, (which makes sense as well) the wall will be the outside surface, any place which you dont want to mesh or you want it to act as a wall, take out the material from that space. hope i make sense.
hwet is offline   Reply With Quote
mesh 3d
[ANSYS Meshing] Meshing a Cylinder anuprdk ANSYS Meshing & Geometry 3 December 9, 2014 12:32
[GAMBIT] Trouble with meshing Chevron Nozzle piyushvjn ANSYS Meshing & Geometry 0 May 26, 2014 15:14
[ANSYS Meshing] Meshing 3d circular cylinder in ICEM darazsbence ANSYS Meshing & Geometry 0 March 11, 2014 16:35
space between vector/scalar scene and cylinder namik STAR-CCM+ 0 March 20, 2011 09:33
[ICEM] (ICEM CFD) meshing over a cylinder vmlxb6 ANSYS Meshing & Geometry 6 August 11, 2010 14:37
