[ICEM] Scripting: How to set topology tolerance in a script
Old   October 28, 2014, 12:17
Default Scripting: How to set topology tolerance in a script
François Grégoire
macfly is on a distinguished road
At some point in my script I had to create surfaces (ic_surface 4pts ...) that are very small (surface side length ~0.001 m) compared to the other ones. Icem CFD would refuse to create the surfaces: Surface sides are too small. Check topology tolerance.
I looked for hours for a scripting command (thanks to the awesome Icem CFD Programmer's Guide...) that sets the topology tolerance once and for all at the beginning of my script. I found nothing in the guide but after a lot of clicks in the GUI and looking at the generated commands in the Replay Control window, I finally found what I was looking for:
ic_set_global geo_cad 1e-4 toler
Very convenient command that is not described in the Programmer's Guide. Hope it helps!
macfly is offline   Reply With Quote
STL import is not working zordiack enGrid 9 July 1, 2014 14:49
[snappyHexMesh] Howto set mesh size tolerance anothr_acc OpenFOAM Meshing & Mesh Conversion 10 July 28, 2012 13:17
[ICEM] Building topology command script files Anorky ANSYS Meshing & Geometry 8 January 11, 2010 07:25
scripting gridgen: why a connector is not saved?? Tim Siemens 2 July 28, 2007 16:11
Help with GNUPlot Renato. Main CFD Forum 6 June 6, 2007 19:51
