August 9, 2012, 02:58 |
long pipe mesh
far
Rep Power: 13 |
I have a long pipe which has narrow cross section.
I need a mesh that must be narrow at cross section and long in pipe length. actually I need a cube mesh which has tall length and short width. pls help me. software: ANSYS 12 |
August 13, 2012, 05:07 |
nitin bansal
Rep Power: 13 |
August 16, 2012, 00:48 |
far
Rep Power: 13 |
August 16, 2012, 03:46 |
nitin bansal
Rep Power: 13 |
.tin and prj files
August 17, 2012, 03:09 |
far
Rep Power: 13 |
let to explain with picture:
attached figures show my mesh and desired mesh. if I use "my mesh", since the pipe is long (10 m) the number of mesh become too high. so I want the mesh like "desired mesh". Can you help me about this? -------------------------------- I only have these files: .cfx-.def-.out-.res |
August 17, 2012, 03:29 |
If you are meshing in workbench, and the tube is indeed just a tube, then you can select a face at a short end and insert "mapped face meshing"
See http://img401.imageshack.us/img401/7...0817092223.png |
August 17, 2012, 09:29 |
#7 | |
far
Rep Power: 13 |
thank you so much I try mapped face meshing but the final mesh become like attached file(mesh.png). Not to "desired mesh". Is there any way? |
August 17, 2012, 09:38 |
Increase the number of cells in radial direction. It's in the image i posted as well.
August 17, 2012, 09:57 |
#9 | |
far
Rep Power: 13 |
but there is a problem which is still exist. the elements on cross section are triangular, but I need rectangular mesh. I attach the picture which shows triangular mesh on cross section. If you look again to "desired mesh" picture in previous posts, you will see rectangular mesh Not triangular. |
August 17, 2012, 10:07 |
#10 |
Ah I see. Then just add a method, choose sweep and change "Free mesh type" to All Quad.
See images : http://i.imgur.com/sA2am.png http://i.imgur.com/nlyKo.png EDIT: Just occured to me that inflation of the boundary layer might be difficult if you want to keep it an hex mesh. For some reason its a hard thing for workbench meshing to do.. ICEM does this easily btw Last edited by jrunsten; August 17, 2012 at 10:47. |
August 17, 2012, 10:52 |
#11 | |
far
Rep Power: 13 |
The mesh has been created normally. thank Josef Runsten for your useful answers. Last edited by trinitron; August 18, 2012 at 03:48. |
August 20, 2012, 02:48 |
#12 |
Couldnt quite let this go, since I knew you wouldn't be able to get a hex mesh with inflation layers using that method. A way that will work, and that isn't that complicated, is to split the cylinder in quarters in Design Modeler, then use a Multizone meshing method. The right click on the method and choose "Inflate this method". Choose the inner and outer wall on the four inflation items and you should be good to go. See http://i.imgur.com/qf2DB.png , or http://www12.zippyshare.com/v/74996362/file.html for the archived project (v14).
If anyone know a better way, other than ICEM, I would be interested in knowing. |
November 5, 2013, 03:39 |
#13 |
Devid
Hi Jrunsten,
I am having difficulties to successfully apply Multizone meshing with inflation to an object, which is half hollow cylinder and half hollow cone. I would appreciate if you share with me your archived examples. Thank you. |
November 4, 2014, 16:45 |
#14 | |
SJ
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
[blockMesh] 3d mesh for a pipe | tsjb00 | OpenFOAM Meshing & Mesh Conversion | 2 | January 30, 2009 04:40 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
