November 17, 2014, 01:23 |
Meshing Problem at boundary
Ebrahim
Rep Power: 16 |
Hello Everybody,
I'm trying to generating a grid (using ICEM) for solving the flow field around a perforated plate. Unfortunately, as can be seen in the attached picture, the generated grid cannot capture the holes' boundaries efficiently. Does anyone know how I can fix the problem? I appreciate your helps in advance. Bests, Ebrahim |
November 19, 2014, 03:47 |
Ebrahim
Rep Power: 16 |
Thank you Ali.
I had a simple mistake in meshing. I should make the curves visible during grid generation. Although I don't set any spacing on curves, making them invisible may lead to such problems. BTW, your suggestion may work as well. Bests, Ebrahim |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
Boundary layer meshing problem in Gambit | Crystal | FLUENT | 0 | June 12, 2009 20:58 |
Please help with flow around car modelling! | Tudor Miron | CFX | 17 | March 19, 2004 19:23 |
GAMBIT meshing problem | Gauthier Lambert | Main CFD Forum | 1 | August 3, 2000 09:22 |
