November 23, 2014, 22:04 |
Overlapping surface
Jonathan Koh
Rep Power: 11 |
Hi, I encountered problem with overlapping surfaces in my geometry, but am unsure of how to check that.
The geometry is a solid block(with windows) enclosed by a domain of fluid. The steps I took to create the geometry is: 1) extrude a block 2) create Enclosure The 2 bodies were then created as One Part, but there happens to have overlapping mesh. The link to the file is attached below: https://www.dropbox.com/s/5ov6r4dzt3...haded.cas?dl=0 I hope someone can advice me on how I can remove the overlapping surfaces in this geometry. Much Appreciated, Jonathan |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[snappyHexMesh] Problem with Sanpper, surface still Rough | Zephiro88 | OpenFOAM Meshing & Mesh Conversion | 7 | November 5, 2014 12:05 |
Surface reactions | netmaster | STAR-CCM+ | 0 | November 9, 2012 21:41 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin | Kaushik | FLUENT | 1 | May 8, 2000 06:47 |
