[DesignModeler] Preparing 2d domain for 2d meshing from 3d geometry (TURBINE)
Old   December 2, 2014, 09:11
Question Preparing 2d domain for 2d meshing from 3d geometry (TURBINE)
Gustaw Cegielski
Goodstuff is on a distinguished road
Dear everyone,
I have this turbine to analyze (see screenshots). It's purely axial, with two rows of guiding vanes (2x38) and a rotor with 34 blades. I'm interested in doing the following thing:
1)Extract about 5 blade-to-blade sections (made out of 5 cylindrical concentric surfaces across the full gaseous domain (the transparent blue cylinder).
2)Make an expanded view of those sections (meaning a 2d view), but not all of them - about 3-5 for each rotor/stator row.
3)Fill the domain
4)Perform meshing in ANSYS Meshing for several different types of simulations (quasi-transient, sliding meshes).
Could you tell me at least how to retrieve the 2d section view?
It might help, that the blades and vanes are pure extrusions of 2d profiles, but the shape of that kind of profile is not quite the same as its expanded blade-to-blade view. The important thing here is, that I do not want to perform a full 3d simulation as of yet. I know, that CFX can show the blade to blade view of the results, but I think, that that would be available only after 3d simulation (or quasi 3d with the unit depth). Besides, Fluent is my current solver.
So it's probably going to be a set of five 2d geometries with identical profiles and different distances between them, right?
Thank you for all the help!
Goodstuff is offline   Reply With Quote
Old   December 10, 2014, 13:09
Default update
Gustaw Cegielski
Dear guys,
Maybe I haven't made myself precisely enough. But since it might be problematic to create the blade-to-blade expanded view, I have decided to create it manually. My question now is:
If i have the proper 2d geometry - as a sketch - and do a "surface from sketches" operation, can I in that manner create a proper domain for 2D meshing in ANSYS Meshing?
My solver is Fluent, therefore no need to do the quasi 3D like in CFX.
Unfortunately - it show zero volume for that domain (I created a polyline to enclose a blade, the created two surfaces and subtracted them by boolean, then assigned material to "fluid" for the resulting surface).
Does the "fill" option work in such cases?
Please help... This is for my bachelor thesis.
2-d, blade, meshing, section, turbine
Floating point exception: Zero divide liladhar CFX 11 December 16, 2013 04:07
injection problem Mark New FLUENT 0 August 4, 2013 01:30
Hydrokinetic Turbine Blade Geometry balaji_hrrn Main CFD Forum 0 November 8, 2012 01:13
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 04:53
Q: how to do a good meshing in turbine usin gambit oscar FLOW-3D 1 March 14, 2009 23:15
