December 10, 2014, 14:47 |
Modeling half a sphere
Isis Ortega
Hello, I need to model half a hollow sphere, like a dome, like a sphere within a sphere and the fluid is going to flow through the space (2cm) between the 2 spheres. Where can i find a tutorial or which tool can i use for it in designmodeler ansys.
thank you. |
December 10, 2014, 17:51 |
#2 | |
Rep Power: 14 |
Hi Orvic,
1. Create>Primitives>Sphere 2. Revolve a 180 degree arc, not a circle create two spheres one inside other with Thin/Surface = Yes Once these two spheres are created you can create>slice from the center. Hope it helps Cheers Kapi |
design modeler tutorials, hollow sphere |
turbulent boundary condition for inlet half sphere shape | asal | FLUENT | 0 | January 7, 2014 11:09 |
[GAMBIT] Asymmetric boundary layer (3D) on surface of a half sphere | Jochen Halfmann | ANSYS Meshing & Geometry | 0 | September 22, 2009 14:16 |
Urgent: Modeling the drag on a stationary sphere in a parabolic Pres driven pipe flow | farhan | CFX | 4 | April 9, 2009 00:36 |
Modeling diffusion of cell (sphere) under flow | Shel | Main CFD Forum | 0 | August 22, 2005 15:26 |
meshing F1 front wing | Steve | FLUENT | 0 | April 17, 2003 12:37 |
