[ANSYS Meshing] Mesh connection inflation layer with mesh in channel
Old   February 6, 2015, 07:46
Default Mesh connection inflation layer with mesh in channel
lufrie is on a distinguished road
Dear Community,
I have a problem with the mesh generation in ANSYS Mesh for CFX. There is fluid volume (the grey and green bodies) that is divided by a solid volume (the brown body). I need inflation layers to resolve the boundary layer in the grey body (a narrow channel) Screenshot forum.jpgand this inflation layers should become connected with the mesh of the green body (which should be appropriatly fine).
How can I reach this? I already tried inflation layers, and Multi Body Methos with fine prism on the green body, but Mesher doesn´t connect the two fluid bodies reasonable.
Is therea a way to do this with Mesher, or do I have to use ICEM for this problem?
Thank you for replies!
Cheers Lukas
lufrie is offline   Reply With Quote
connection, inflation layer, mesh 3d
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel colinB OpenFOAM Meshing & Mesh Conversion 14 December 12, 2018 08:07
[snappyHexMesh] Unwanted mesh created by snappyHexMesh--baffle bieshuxuhe OpenFOAM Meshing & Mesh Conversion 2 April 23, 2014 01:59
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 04:31
[snappyHexMesh] Boundary layer generation problems ivan_cozza OpenFOAM Meshing & Mesh Conversion 0 October 6, 2010 13:47
