[ICEM] Twisted wire surrounding pipe
Old   March 8, 2015, 12:49
Default Twisted wire surrounding pipe
geod is on a distinguished road
Currently I am trying to tackle a problem with a meshing in ICEM CFD, of a double pipe heat exchanger, with the inner pipe having a wire wrapped around it. I have managed to do this as an unstructured mesh but the quality is so poor that it will be un-usable in fluent so I would like to try structured. I have managed to generate a structured mesh for the tube in tube without the twisted wire surrounding the inner pipe, however am struggling to figure out how to go about this problem with the helical wire. Any help would be much appreciated!
Here are a couple pics of the geometry I am looking to tackle:
Cheers
geod is offline   Reply With Quote
Old   March 8, 2015, 15:52
Javi
FJSJ is on a distinguished road
Hi geod,
I think you should try to block the wire with an o-grid and then extrude it along the curve. You have the option under "create block". Then, you can split it with multiple planes and associate the different edges to the wire shape.
FJSJ is offline   Reply With Quote
Old   March 9, 2015, 08:58
Hi FJ,
Thanks for the reply. I understand the use of extrude along the curve, and think I'd be able to perform this method if blocking the twisted wire alone, however when combined with the blocking of the two pipes is where I get bit confused. I have blocked the two pipes but finding it quite hard to figure out how to then split it to mesh the wire. As you can see the wire's face is nearly perpendicular to the face of the pipes.
How can I go about splitting the blocking from the pipes to meet this face?
Thanks
Old   March 10, 2015, 12:26
still not made any progress on this help would be much appreciated! I need to mesh the two pipes and the twisted wire
[DesignModeler] DesignModeler Pipe within pipe shields ANSYS Meshing & Geometry 13 November 25, 2018 22:14
Double Walled Pipe Boundary dahvqaz FLUENT 2 December 5, 2012 10:14
My Revised "Time Vs Energy" Article For Review Abhi Main CFD Forum 2 July 9, 2002 09:08
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
