[DesignModeler] Airfoil coordinate importing in DesignModeler
Old   March 28, 2015, 14:42
Default Airfoil coordinate importing in DesignModeler
Osman
Aerofluid is on a distinguished road
I am trying to draw wing in ANSYS Design Modeler. I have imported the airfoil coordinate file in DM through 3-D curve. But the geometry is not changing to blue color after generating the curve and also I cannot modify the geometry. Where am I doing wrong? Can someone, please, help me on this?
TIA
Aerofluid is offline   Reply With Quote
Old   March 29, 2015, 14:14
Rahul
rrr311 is on a distinguished road
Send a message via AIM to rrr311 Send a message via Skype™ to rrr311
Did you use Concept > Surfaces from Edges?
http://www.cfd-online.com/Forums/att...-points-dm.jpg
Best,
Rahul
rrr311 is offline   Reply With Quote
Old   March 31, 2015, 16:08
Osman
Best,
Rahul
Thanks a lot Rahul. It is working now.
But what is the problem with concept>3D curve option? Can you kindly explain it? I am mainly following a tutorial and it is done by that method but in my case, it didn't work.
Regards,
Osman
Old   March 31, 2015, 16:44
Rahul
Osman,
3D curve as the name suggests, creates a 3D curve (a line body). You need to create a surface (surface body) from the 3D curve, if you trying to perform 2D simulations. You would have to extrude the surface (solid body), if you are trying to do 3D simulations. Complex 3D wing profiles can be modeled using the sweep/blend options.
Best,
Rahul
Problem with airfoil shape optimization robyTKD SU2 Shape Design 7 March 7, 2022 16:18
SU2 AOA optimization 454514566@qq.com SU2 9 March 7, 2022 16:17
Airfoil coordinate importing in Designmodeler Aerofluid FLUENT 0 March 27, 2015 02:19
2D FFD Optimization RLangtry SU2 2 August 5, 2014 09:48
Problem with restart solution in shape_optimization.py robyTKD SU2 Shape Design 21 May 29, 2013 09:26
