[DesignModeler] Export "Details of Body" in Excel (Scripting)
Old   April 14, 2015, 19:21
Question Export "Details of Body" in Excel (Scripting)
Kapi is on a distinguished road
Hello Everyone!
I was wondering if its possible to export the "details of body/face/edge" from the designModeler to Excel or not.
We get details on the left pane when you click a body/face/edge, that information or by selecting Tools>Analysis Tools> Entity Information on the left side, either of these things details surface area, volume, area, number of edges, faces and so on.
I want to export this data with the help of script.
So basically when my script is running to create this geometry and revolve/extrude it to create body, it should be able to pick that body so that information is picked and then export it in given excel workbook.
If anyone has any idea then do let me know!!
cheers
KAPI
Kapi is offline   Reply With Quote
Old   April 15, 2015, 21:06
Solved!
In mesh, select a body and then give following code to get Volume and area!
body.Volume;
body.Area;
Hope it helps others!
Cheers
Kapi
Old   May 11, 2015, 07:17
Post
kar.coep is on a distinguished road
Hi Kapi!!!
How do we get face's details like area and surface type?
Any command apart from entity information?
Thanks,
Kartiki
kar.coep is offline   Reply With Quote
Old   May 12, 2015, 18:34
Hi Kar,
You can select face details same as body!
faces(i).Area;
I don't know any command for entity information tool.
So yea if you are after Surface Type then you need find function for that like area, volume!
Hope it helps
Cheers
KAPI
Naming export files in Workbench scripts evan247 CFX 1 January 22, 2015 20:23
Unable to install OpenFOAM 1.6-ext Maimouna OpenFOAM Installation 23 May 8, 2014 05:47
How can I export transient results data to EXCEL popi CFX 8 February 22, 2014 04:31
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
how to export data to Excel bikash FLUENT 3 September 14, 2004 20:58
