[ICEM] ICEM - FLUENT - mesh quality compare
Old   May 25, 2015, 21:33
Default ICEM - FLUENT - mesh quality compare
shereez234's Avatar
M Sereez
shereez234 is on a distinguished road
Dear fellow CFD users!
I would be grateful if people can suggest me good suggestions for ICEM mesh quality ( and I mean Hexa unstructured blocked mesh).
I have been doing a mesh of about 9 million elements. After a lot of input I am able to achieve a quality of 0.3 and min angle above 18. Skewness is above 0.2.
However when I take it to fluent it gives me orthogonal quality of 0.0003 which is too low. Why does fluent show low quality for the mesh?
And also I found out that the no of cells in ICEM was about 9.3 million and in fluent it got reduced to 8.8 million approximately. why does this happen?
Can people who use CFD ( specially fluent and ICEM) give suggestions on their best practices with respect to mesh quality improvement, rule of thumb, guide lines. Please input your ideas.
Cheers!
Shereez
shereez234 is offline   Reply With Quote
Old   May 29, 2015, 18:11
shereez234's Avatar
M Sereez
Any one want to share their experience and views on acceptable quality and most important criterion? I recently read that CFX is less sensitive to mesh quality than fluent.
Old   May 29, 2015, 18:15
shereez234's Avatar
M Sereez
Also when you have two wings and a fuselage in aircraft as wing body and you know Sref ( reference area is 100m2 approx for half model) do you put 200 m2 for full model even if you wanted to calculate lift per zone? ( per wing) or do you put 100m2 still?
I know this question is not related to meshing but still..! sorry about that
Old   May 30, 2015, 13:35
shereez234's Avatar
M Sereez
Nevermind about this thread now! Found the quality criterion that is good enough
Old   November 24, 2015, 02:44
Attique Javaid
attiquejavaid08 is on a distinguished road
mesh of about 9 million elements. quality of 0.3
min angle above 18
fluent gives orthogonal quality of 0.0003
Which skewness? I see in ICEM after conversion to unstruc, 'equianlge skewness' and 'skew'. both are different. when imported to Fluent, it shows third type in quality check.
share your feedback, which to check?
How did you solve this issue? did you go ahead with this orthogonal quality?
what's criteria you found?
share please.
regards,
AJ
attiquejavaid08 is offline   Reply With Quote
Old   November 28, 2015, 13:57
shereez234's Avatar
M Sereez
share please.
regards,
AJ
Hey man sorry for the late reply:
http://www.cfd-online.com/Forums/ans...eria-icem.html
Check 4th post in the above Link. I can tell you that Tgrid Skew is the equivalent of Fluent's skew (squish) atleast I believe.
But refer to that post for the rule of thumb
Regards
Shereez
Error loading ICEM mesh into Fluent mix FLUENT 3 July 5, 2015 20:23
[ICEM] ICEM 2D Mesh to Fluent 14.5 Lmecano ANSYS Meshing & Geometry 1 February 18, 2015 04:56
Export mesh from ICEM CFD for Fluent summerdream ANSYS 2 September 10, 2013 12:12
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 12:11
[ICEM] Export unstructured periodic mesh from ICEM CFD to Fluent ivanddd ANSYS Meshing & Geometry 1 February 3, 2011 00:51
