[ANSYS Meshing] When will Ansys Meshing have the capabilities of ICEM CFD? |
June 3, 2015, 07:04 |
Mr CFD
Rep Power: 14 |
Does anyone in the know have an idea of when Ansys Meshing will have the full capabilities of ICEM CFD?
Thanks |
June 12, 2015, 05:12 |
Paritosh Vasava
Rep Power: 22 |
I think it will be a long time before Ansys will stop developing either of the meshing software. However (this I heard at a recent Ansys seminar) now users don't have to pay for both the meshing software. If you have a valid license for one, the same license should work for the other as well.
June 12, 2015, 09:03 |
Javi
Rep Power: 16 |
That's true Paritov. I have been recently in a Regional User Conference and they said the same thing. But I think you need to have at least 16.1 release. I can imagine this is part of the evolution to ANSYS AIM...
June 16, 2015, 11:03 |
Mr CFD
Rep Power: 14 |
Thanks for the heads up.
I like the user interface of Ansys Meshing but it's not as powerful as ICEM. |
June 16, 2015, 14:55 |
Didn't work here
I just now installed ICEM 16.1 and it didn't run due to lack of ICEM license.
June 17, 2015, 14:02 |
Mr CFD
Rep Power: 14 |
Do you have the correct license server version installed, and is the license pointing to the correct address?
June 17, 2015, 17:51 |
nm
Rep Power: 13 |
as a gambit and ansys mesher user, can you tell me what capabilities icem has apart from these two?
I find the blocking to be extremely time consuming and tedious for complex 3d geometries. |
June 18, 2015, 04:13 |
Mr CFD
Rep Power: 14 |
I can't talk about Gambit - I don't use it. It's a retired software now isn't it?
Regarding Ansys Meshing vs ICEM: In Ansys Meshing if you want a structured hexahedral mesh, you need to decompose your geometry first in Ansys Design Modeler - this is tedious. In ICEM you can "block" certain regions of your geometry without decomposing the geometry in Design Modeler. This means you can quickly make structured hexahedral portions in areas you desire, and then back fill the rest with tet cells if you so wish. In ICEM there are more controls over the cells and the way they are computed too. I use Ansys Meshing quite a lot - but it's no ICEM. |
June 18, 2015, 09:07 |
#9 |
June 19, 2015, 17:08 |
#10 |
nm
Rep Power: 13 |
thanks.
So whole blocking, don't you end up doing the same amount of work required to slice the geometry into sweepable blocks on workbench? I really hope they would make the multizone usable. It's utterly useless in its current shape. Gambit allows much more flexible sizing, mesh sweeping and abolsutely full control on the mesh. But it's discontinued... workbench mesher however is incredibly time consuming to cfd meshes, no control except for some edge sizing which is again useless unless it's a swept mesh. I really don't like the tet meshing algorithm of wb. I have a lot of experience on both gambit and wb mesher but little in icem. but from how I used icem, I felt like it would be a pain for 3d geometries, I mean blocking is not straight forward and for complex 3d geometries, blocking could be a nightmare right? |
[ICEM] ANSYS Meshing & ICEM with one license | vasava | ANSYS Meshing & Geometry | 0 | March 20, 2015 08:13 |
[Other] Ansys Meshing vs Ansys ICEM CFD | JuPa | ANSYS Meshing & Geometry | 5 | September 19, 2012 09:48 |
[ICEM] ANSYS ICEM CFD YouTube Tutorials | mech.ismail | ANSYS Meshing & Geometry | 1 | September 4, 2012 12:19 |
[ICEM] ICEM CFD Boundary Conditions not found in Ansys Fluent | sammyraj | ANSYS Meshing & Geometry | 2 | April 12, 2010 15:23 |
ANSYS ICEM CFD smoothing mesh corner chamfered | Hans | CFX | 4 | January 26, 2006 16:00 |
