June 9, 2015, 12:20 |
Surface mesh
Hyowon Lee
Good morning, ICEM experts.
When meshing a circle surface on a cylinder, Is there any way to make mesh on the basis of central axis? Also, the mesh should be filled with hexahedrons only except 10 triangular prism around the central axis. ICEMers can easily understand it if you see some pictures on the link. Pictures is added in my dropbox link as below. https://www.dropbox.com/sh/dsdgyzm4p...qobBHxsMa?dl=0 Thank you. Sincerely. |
June 10, 2015, 05:11 |
Sebastian Engel
Rep Power: 20 |
Hi Hyowon,
the kind of mesh you described is created within a few steps. You should start by creating an o-grid in the initial block: ogrid.jpg Then, collapse the newly created central block. You can do this by selecting "merge vertices". Choose the option "multiple vertices". Selected the first vertex marked with "base" in the previous picture. Then, select the remaining vertices (1-3). The result will be a bit distorted. Just move the remaining vertex back to the central axis. Apply your edge settings and you'll get a mesh similar to the following picture: premesh.jpg With regards, Sebastian |
June 10, 2015, 13:42 |
Hyowon Lee
Dear. Sebastian Engel
Thanks for your help. Sincerely, Hyowon |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
[snappyHexMesh] Problem with Sanpper, surface still Rough | Zephiro88 | OpenFOAM Meshing & Mesh Conversion | 7 | November 5, 2014 12:05 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
