[DesignModeler] 3mm Trailing edge radius on closed airfoil
Old   November 14, 2013, 09:08
Default 3mm Trailing edge radius on closed airfoil
Henrik Dahlberg
henrikdahlberg is on a distinguished road
I'm trying to create a rounded trailing edge with a radius of 3 mm on a airfoil setup with 3 elements. The individual elements are Line Bodies created with 3D Curve from imported coordinates. The coordinates of each element ends like in the example below:
1 65 0.741569 -0.370387 0.000000
1 66 0.783980 -0.382998 0.000000
1 67 0.820996 -0.393223 0.000000
1 68 0.852138 -0.401242 0.000000
1 69 0.877052 -0.407157 0.000000
1 70 0.895357 -0.411035 0.000000
1 71 0.906638 -0.413040 0.000000
1 0
I tried using Vertex Blend to fillet the trailing edge, but there is no vertex to select at the trailing edge. I also tried sketching it manually, but I can't set the tangential constraint on both the upper and lower side since there is only 1 edge on each element.
Does anyone know how to fix this? Maybe there is a way to create a vertex at the trailing edge?
Thank you.
henrikdahlberg is offline   Reply With Quote
Old   June 10, 2015, 05:04
aer
Julia
aer is on a distinguished road
Originally Posted by henrikdahlberg View Post
1 0
Thank you.
Hi
I also have this problem. do you find a solution for it?
Thanks.
aer is offline   Reply With Quote
Problem with airfoil shape optimization robyTKD SU2 Shape Design 7 March 7, 2022 16:18
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
stagnation point at the trailing edge of the airfoil mahzad Main CFD Forum 7 August 24, 2012 03:23
airfoil trailing edge modelling in gambit morteza08 Main CFD Forum 3 June 4, 2010 13:36
