[GAMBIT] problem in deleting a edge
Like Tree4Likes
  • 1 Post By -mAx-
  • 1 Post By -mAx-
  • 1 Post By -mAx-
  • 1 Post By -mAx-
Old   June 9, 2015, 10:51
Default problem in deleting a edge
Aja
aja1345 is on a distinguished road
Hi everybody
I have a question:
edge.602 is not deleted in the following model. why?
Please, download the following model and If model have the problems, I am grateful that guide me about each problem because I am modifying this model.
http://www.4shared.com/file/DJ7HVfuhba/AAAAA112.html
Thanks,
Best,
Amir
aja1345 is offline   Reply With Quote
Old   June 10, 2015, 01:51
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
your file seems to be deleted.
I loaded your last dbs file, and edge 602 is duplicated (you also have edge 603)
Basically you cannot delete an edge which belongs to a surface.
So in this case you need to connect both edge.
Doing that only one edge will remain
aja1345 likes this.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   June 10, 2015, 06:18
Aja
I think that Gambit is not promising and It is not agreeable with Solidwoks.
Please, show v_vertex.881 in the following link. In this vertex, The edges are skew.(v_edge.971,v_edge.961,v_edge.966, v_edge. 970, v_edge.962,v_edge.967)
http://www.4shared.com/file/Q26w0_VOce/AAAA12.html
These edges create many problems for numerical computational in the Fluent, Correct?
In my opinion, I should design this model in Gambit.
I am grateful that guide me this case.
Thanks,
Best,
Amir
Old   June 10, 2015, 06:39
-mAx-'s Avatar
Maxime Perelli
the problem isn't gambit, but the quality of your cad import.
did you import iges, step, something else?
aja1345 likes this.
Old   June 10, 2015, 07:44
Aja
Yes, I imported iges. In fact, I designed this model in Solidworks2013.
I am grateful that guide me more. I really worked in this modeling.
If I cant solve this problem, I have to design in Gambit., this design is difficult in this software.
Thanks,
Best,
Amir
Old   June 10, 2015, 08:04
-mAx-'s Avatar
Maxime Perelli
can you export step file from solidworks?
aja1345 likes this.
Old   June 10, 2015, 08:19
Aja
Yes, please show the following figure. Also, parasolid file is imported.
But I dont know that how to set of Gambit for step file and another files.
Old   June 10, 2015, 08:37
Aja
Four type of files is placed in the following link(IGs,Step, parasolid,...):
http://www.4shared.com/rar/HFVNeaKSce/CFD_Y.html
I am grateful that you check.
Thanks,
Old   June 10, 2015, 09:12
-mAx-'s Avatar
Maxime Perelli
Don't generate all the splits in solidworks.
Do them in Gambit.
aja1345 likes this.
Old   June 10, 2015, 10:55
Aja
Do them in Gambit.
Why?
If I split Faces in solidworks, modeling is easier than the splits are done in gambit.
But I think that I should do these splits in Gambit and you are right. Please show the following link, particularly in trailing edge of blade. Is there any problem for analysis of fluent?
Does shape of trailing edge make any problem? In other words, Does trailing edge increase error of computational?
what is your opinion?
http://www.4shared.com/file/K-9okRnEba/AS11.html
Only i want to know about Gambit.
Thanks,
Best,
Amir
Old   June 11, 2015, 01:50
-mAx-'s Avatar
Maxime Perelli
did you do something after the import?
because normally you should have real surfaces, and here you have virtual
try also with parasolid
Old   June 11, 2015, 09:22
Aja
No,
You are right.
I import as shown the below:
(with format IGS--import>IGES>Import IGES file>activate Negative in import options> then selecting IGS file in File name)
I try with parasolid, but it is not imported. Maybe I dont know that how to set options of Gambit.
[ICEM] Shifted Periodic topology venkat_aero2007 ANSYS Meshing & Geometry 17 August 27, 2013 01:41
[Commercial meshers] Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 maverick OpenFOAM Meshing & Mesh Conversion 2 June 18, 2011 04:36
Through-Flow solver, Leading-Trailing edge problem Menander Main CFD Forum 0 May 14, 2008 18:14
mesh control problem TUM CFX 4 July 27, 2001 16:17
