[GAMBIT] can any one give a tutorial for a 2d centrifugal pump |
December 31, 2011, 19:07 |
CFD
Rep Power: 16 |
can any one give a tutorial for a 2d centrifugal pump how to make a mesh and how to analysis in fluent from 0 to finsish plz help
January 4, 2012, 01:43 |
Maxime Perelli
Rep Power: 41 |
In memory of my friend Hervé: CFD engineer & freerider |
June 21, 2013, 09:00 |
keyhan
Rep Power: 12 |
can any one give a tutorial for a 2d centrifugal pump how to make a mesh and how to analysis in fluent from 0 to finsish plz help,,please send to keyhan_mec@yahoo.com
June 16, 2015, 07:36 |
Centrifugal pump
Issa
Rep Power: 12 |
Hello al
How to make a mesh between the mobile part ( Impeller) and the fixed part ( Volute) of a centrifugal pump 2D in Gambit . |
June 17, 2015, 01:30 |
Maxime Perelli
Rep Power: 41 |
you have to "separate" both meshes. For that you only need to disconnect both volumes (stator and rotor), and apply interfaces.
Later you will be able to run moving mesh, and you will see that rotor mesh will rotate (but not stator)
Centrifugal pump convergence issue | bhatiadinesh | CFX | 6 | April 3, 2020 06:57 |
3D centrifugal pump y+ ? | spk | FLUENT | 2 | July 13, 2016 14:14 |
Centrifugal Pump simulation | b.eshghi | Main CFD Forum | 8 | November 13, 2010 02:06 |
[GAMBIT] influence between angle in impeller blade and centrifugal pump performance | barak182 | ANSYS Meshing & Geometry | 2 | August 18, 2010 03:07 |
HOW to calculate the NPSHR of centrifugal pump | water pump | CFX | 2 | August 2, 2010 19:59 |
