[ANSYS Meshing] Minimum Element Size in Design Modeler?
Old   June 26, 2015, 09:39
Default Minimum Element Size in Design Modeler?
Andrew B
abouma is on a distinguished road
I'm an undergrad student doing summer research, and trying to model a particle collision between two simple spherical particles. The particles have diameters in the range of 50 - 200 microns. I am trying to run a 2D axisymmetric simulation using Ansys Explicit Dynamics in Workbench 15.0. I can refine the mesh near the contact point using a body sizing mesh with a sphere of influence and the mesh generates just fine (with element sizes of about 1 micron). When the simulation runs though, I immediately get "Zero or negative element volume" errors. If I increase the element size I can get it to run, but I lose the resolution I want to have. I think it might be a precision problem, if the elements are so small that the volume rounds to zero. Is there any way around this? Any help or pointers would be appreciated.
abouma is offline   Reply With Quote
explicit dynamics, mesh 2d, micro nano scale, minimum size, negative cell volume
[Gmsh] 3D Mesh conversion from gmsh-2.5.0 to OpenFOAM Ancioi OpenFOAM Meshing & Mesh Conversion 17 January 8, 2019 23:50
[Other] dynamicTopoFVMesh and pointDisplacement RandomUser OpenFOAM Meshing & Mesh Conversion 6 April 26, 2018 07:30
[snappyHexMesh] crash sHM H25E OpenFOAM Meshing & Mesh Conversion 11 November 10, 2014 11:27
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
Design Modeler to ICEM..... Joe CFX 0 January 24, 2008 03:39
