[ANSYS Meshing] Problem meshing cylindrical rotor with Hex and Inflation
Old   July 29, 2015, 12:58
Default Problem meshing cylindrical rotor with Hex and Inflation
Neo_Zeo is on a distinguished road
Hello!
I´m new here and I´m working in my final project. I have looked for similar threads in the forum but I haven`t found anyone.
I am studying a steam turbine rotor. I have worked testing just simple cylinders to validate my manual calculations with Ansys results.
And now I´m working in the real rotor. I need an hexa mesh, and apply some inflation layers in the surface to provide a better calculation of the thermal layer. But I find problems like these ones:
It´s a big problem for such a simple geometry, so I think I have failed in some important thing.
Could you help me?
Neo_Zeo is offline   Reply With Quote
Old   July 29, 2015, 20:47
hwet is on a distinguished road
Is this a mechanical problem or fluids related?
hwet is offline   Reply With Quote
Old   July 30, 2015, 04:41
Static - Structural, and the solution will be exported to the setup of a transient thermal analysis (where this mesh will be used, I thought I would be able to use the same mesh for both problems)
Old   August 1, 2015, 12:00
amin.z's Avatar
Amin
amin.z is on a distinguished road
I think you're following a strange method!!
In CFD Problem we have to set some inflation near the wall for decreasing numerical diffusion near walls due to boundary layer effects!
Now, Do you want set inflation in a structure problem!?
I think the inflation has been suppressed by ANSYS logically.
amin.z is offline   Reply With Quote
Old   August 1, 2015, 15:32
I`ve tried to make a hexa mesh with inflation in a transient thermal analysis and it hasn´t work. However I can apply this mesh in a cylinder geometry or in smaller geometries.
I can make a Tri mesh with inflation with any problem in both structural or thermal
Thank you! I will keep investigating.
[ANSYS Meshing] Hex dominant method and local inflation carlp ANSYS Meshing & Geometry 8 July 12, 2012 08:02
Getting prism to inflate into mixed tet-hex meshes Joe CFX 16 October 10, 2011 07:06
