[ICEM] Delete elements from unstructured mesh
Old   August 22, 2015, 02:16
Default Delete elements from unstructured mesh
beyonder
beyonder1 is on a distinguished road
I have created a mesh along 2D cascade of airfoils using ICEM CFD. I found some elements near trailing edges that were creating some problem. I deleted few elements and then i imported that mesh to CFX. The surface parts are vanished from the parts list. Earlier it was showing when i didn't deleted elements.
Does this have anything to do with deleting few elements arbitrarily and do i need to do anything after deleting elements and before exporting. Kindly suggest some insight.
beyonder1 is offline   Reply With Quote
Old   August 22, 2015, 09:25
shereez234's Avatar
M Sereez
shereez234 is on a distinguished road
You can't delete elements manually and leave it like that. That will be a problem.
shereez234 is offline   Reply With Quote
Old   August 22, 2015, 09:29
shereez234's Avatar
M Sereez
You should try and fix the trailing edge problems because a quality mesh there defines a quality solution for your simulation
unstructured mesh generation with strictly constrained boundary in simple space goujl Mesh Generation & Pre-Processing 0 January 29, 2015 10:44
[ICEM] Removing the Unstructured Mesh from an ICEM Project scribby182 ANSYS Meshing & Geometry 2 February 1, 2013 19:00
