[GAMBIT] creating a periodic condition in Gambit |
September 6, 2015, 17:43 |
Aja
Rep Power: 14 |
I want to link the faces periodically. I do this work as follow, please see the following video file: http://www.4shared.com/rar/faKnnGGSba/Untitled_38.html In fact, I select both of reverse orientation and periodic option because the mesh is same and equal in these two faces with this way. Is this work correct? I am grateful that guide me. Thanks, Best, Aja |
September 7, 2015, 02:16 |
Maxime Perelli
Rep Power: 41 |
zip your file instead of rar
and display some result in fluent for checking if your periodicity work
In memory of my friend Hervé: CFD engineer & freerider |
September 7, 2015, 03:03 |
#3 | |
Aja
Rep Power: 14 |
Zip file: http://www.4shared.com/zip/rC3axdnFce/Untitled_38.html This video is just a example of my way(method of creating periodic boundary condition) in simulation of turbine. In other words, I do this way for creating periodic faces in turbine. In fact, i want to know that this way is correct or not and the notes are appeared in fluent is related to this way or not. please see the following thread: http://www.cfd-online.com/Forums/flu...tml#post562056 I think that periodic condition work, Please see the following figures: one blade: eight blade: But what is reason of appearing these notes? I am really grateful that guide me about this cases. Thanks max, Best, Aja Last edited by aja1345; September 8, 2015 at 02:37. |
September 7, 2015, 04:21 |
Maxime Perelli
Rep Power: 41 |
what kind of bc did you create?
the link option is just a way to copy and paste exactly the same mesh on another surface. Doing that, it will not generate a periodic BC. But when I see your last picture I assume you created the priodic BC and it work (Now just be sure the the flowfield is also comuted with periodicity) The othe warning message is about interfaces. You probably created interfaces in Gambit, but you need to define them in Fluent (Define/grid interfaces)
September 7, 2015, 05:13 |
#5 | |
Aja
Rep Power: 14 |
The periodic BC need to create exactly the same mesh on another surface. For this reason, I used link option. Therefore, Is this work correct? I doubt about reverse orientation option. I also selected this option. Is it correct? First, I should do above work , then I define in grid interface. But these notes are appeared for displaying mesh. why? thanks |
September 7, 2015, 09:20 |
Maxime Perelli
Rep Power: 41 |
can you elaborate how did you create your interfaces?
September 7, 2015, 14:43 |
Aja
Rep Power: 14 |
Thanks your answer,
Two kind of interfaces are created in this work. 1. interfaces . 2. interfaces for periodic BC. Please see the following video files, you will understand. gambit: http://www.4shared.com/zip/W-LQKPwcce/Untitled_39.html fluent: http://www.4shared.com/zip/fSi2mFzCba/Untitled_40.html I am grateful that guide me about this problem. Thanks, Best, Aja Last edited by aja1345; September 8, 2015 at 04:47. |
September 8, 2015, 01:18 |
Maxime Perelli
Rep Power: 41 |
on your video you set the type of boundary for "periodic" and "interface" as wall.
set "periodic" as periodic (Type) and "interface" as interface (Type)
September 8, 2015, 02:21 |
#9 |
Aja
Rep Power: 14 |
September 8, 2015, 02:43 |
#10 |
Maxime Perelli
Rep Power: 41 |
seems to be ok.
just ignore the warnings and compute
September 8, 2015, 03:50 |
#11 |
Aja
Rep Power: 14 |
September 8, 2015, 04:14 |
#12 |
Maxime Perelli
Rep Power: 41 |
run your simulation
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
About periodic boundary condition. | kohel_11 | FLUENT | 3 | July 30, 2013 07:37 |
Periodic condition operated by user fortran | MechE_HYU | CFX | 0 | April 25, 2012 07:46 |
Boundary condition for periodic flow solution in Gambit | ghmahtabi | Main CFD Forum | 2 | March 20, 2012 16:22 |
periodic boundary condition | tucker | FLUENT | 3 | May 23, 2005 06:56 |
