September 13, 2015, 04:31 |
the problem of 3D boundary layer
wanghuo
Rep Power: 11 |
Hello friends!
Fluid is in this geomery 11.jpg ,so I want to mesh the boudary layer ,the boudary layer is in this picture22.jpg.In the corner of the geomery the boudary is in this picture 33.jpg .My problem is that length of mesh 1 is diffent from the mesh of 2 so the quality of the volume mesh in the corner is poor ,how can I do to make the mesh have the same length ?Thank you very much ! your sincerely hotboy! |
September 14, 2015, 01:06 |
Maxime Perelli
Rep Power: 41 |
control the mesh on the edges
https://www.sharcnet.ca/Software/Gam...mesh_edge_mesh
In memory of my friend Hervé: CFD engineer & freerider |
September 14, 2015, 03:04 |
wanghuo
Rep Power: 11 |
Dear mAx!
Thank you very much ,I'll try to do it as you tell me . |
September 14, 2015, 04:49 |
#4 | |
wanghuo
Rep Power: 11 |
I control the mesh on the edges ,but the result is this 992B26C54D5C5B496AB6E497E194EA0B.jpg what's the problem? |
September 14, 2015, 08:20 |
Maxime Perelli
Rep Power: 41 |
you need to mesh your surfaces first
September 14, 2015, 09:06 |
wanghuo
Rep Power: 11 |
Dear mAx!
Thank you very much for your help .I mesh the surfaces first but the problem is still exist CEDA4D0FA28BDB406009426BE47C0381.jpg. My geomery is there https://drive.google.com/folderview?...Gc&usp=sharing |
September 14, 2015, 09:19 |
Maxime Perelli
Rep Power: 41 |
no problem from my side
Untitled.png I just picked both edges and applied exponent node distribution Else you can define a size function with edge.7 as source and your volume as attachment. Gambit will automatically refine the mesh in this area
In memory of my friend Hervé: CFD engineer & freerider Last edited by -mAx-; September 15, 2015 at 01:01. |
September 14, 2015, 21:02 |
wanghuo
Rep Power: 11 |
Dear mAx!
With your help I fix this problem .Thank you very much! Best wishes for you! |
High aspect ratio mesh problem for flat plate boundary layer | sam1364 | OpenFOAM | 3 | May 14, 2020 11:11 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
problem with boundary layer | Bharath | Main CFD Forum | 1 | July 11, 2008 09:06 |
errors | Fahad | Main CFD Forum | 0 | March 23, 2004 13:20 |
